What is this piece under the hood
Old May 21, 2024 | 02:24 PM
moleskijag's Avatar
Default What is this piece under the hood
The white/yellow piece in this photo is broken, what is this whole thing, i beleive it has something to do with the accelerator/traction control? Thanks for your help.
1997 Jaguar XJR
Old May 22, 2024 | 08:22 PM
motorcarman's Avatar
CORRECT. Traction control throttle actuator.
Old May 22, 2024 | 08:56 PM
Parker 7's Avatar
Might try to glue back together with JB - Weld
Comes in yellow and red version with short 5 min or 4 hour set time before longer cure time
4 hour set time recommended
If you take the top of the actuator apart for more cable access it is a can of worms to be avoided
If you look at the very bottom of the actuator cylinder there are 2 wires that can have the insulation deteriorated and breaking off
On the later model years of the X300 there is an adjustment to the cables to the actuator that effects idle from reading others , I wouldn't touch that yet ( adjustment ) if an idle issue
The actuator is between the cable run from the foot pedal to the throttle butterfly
Idle is a common issue with the supercharged version
Old May 24, 2024 | 10:38 AM
cdma's Avatar
Because that gets broken often, I protected mine with a thick roll of cloth wire wrap. If you work on your car, or someone else does, it is an excellent idea to protect it.
XJ8JR
Mar 28, 2024 04:09 PM
AZDoug
Feb 5, 2024 04:26 PM
silversurfer1221
17
Oct 9, 2021 11:27 AM
jagginSTAG
Exterior
Jun 7, 2011 10:30 AM
