What is this and where does it go?
Old Jan 24, 2022 | 11:13 PM
Spud Maat's Avatar
Default What is this and where does it go?
Exactly as title says….. found this just hanging around near my airbox.
need to fix the wiring on it but also need to know what it is and where it goes.
Old Jan 25, 2022 | 12:01 AM
Parker 7's Avatar
Coolant level sensor ?
should be one in the reservoir tank
Old Jan 25, 2022 | 12:03 AM
Spud Maat's Avatar
if it is where exactly would it connect in?
*from a google search it seems that you are correct, now i just gotta work out if it works and where to put it.
Old Jan 25, 2022 | 12:48 AM
It clips into a tubular recess in the base of the Expansion Tank (see item 3):
The harness looks a bit chewed at the connector. Perhaps a PO was trying to turn off a warning light........
Old Jan 25, 2022 | 12:55 AM
Spud Maat's Avatar
yeah i think the sensor might be busted as it looks like the insulation was stripped back and the wires twisted together to close the connection and bypass the sensor.
Old Jan 25, 2022 | 03:52 AM
Spud Maat's Avatar
Maybe there was once a problem that has now been resolved?
I patched up the wiring, turned the car in, had coolant level warning, put the sensor where it belongs and error gone…..
so i dunno but all G the wiring is patched and the the sensor is in its home.
Old Jan 25, 2022 | 05:31 AM
Enjoy the moment. It's not often a Jaguar repair can be completed with nothing more than a length of insulating tape.
Old Jan 25, 2022 | 05:35 AM
Spud Maat's Avatar
hahaha... i am beginning to notice that.....
what looks to be a small quick easy job always comes a big mission....
goodwin3026
Nov 11, 2021 02:09 PM
Darrenmb
May 30, 2021 01:08 PM
Yash swamy
Apr 7, 2020 09:22 AM
Curt Lee
Aug 13, 2015 07:33 PM
alabbasi
Feb 5, 2014 12:09 PM
