Windows Malfunctioning
Old Jan 7, 2023 | 07:42 AM
hbear's Avatar
Default Windows Malfunctioning
x300 passenger windows doing me . front sometimes wors ok .in.rear goes down on its ownnow disconceted front ok sometimes engine off other times works once..engine running. works once.stop remove key wait turn on on same again yours totaly baffled
Old Jan 11, 2023 | 09:04 PM
Don B's Avatar
Hi hbear,
I have revised the title of your thread so that other members will know the nature of your questions. Hopefully some of our knowledgeable members will be able to help. When you title a thread with just your username, we don't know the nature of your post, so it's too easy to simply skip it.
Cheers,
Don
Old Jan 11, 2023 | 09:33 PM
Parker 7's Avatar
Have you removed the door panel to look at the driver door master controller connectors?
What I found on mine was the lock bar holding the sockets in the connector was loose allowing the sockets to not make contact with the pins
Ziffo
24
Feb 15, 2022 03:34 PM
AmyMoore27
F-Pace (X761) / C-X17
Aug 11, 2021 07:50 AM
nbewafaa
Nov 23, 2016 07:24 AM
mcervantes7
Jan 12, 2012 04:05 PM
badmojo
Dec 30, 2011 12:24 PM
