Wiper Motor Re-assembly Woes Arm dips down before wiping.
Old Jul 17, 2016 | 06:05 PM
Alan Stoldt's Avatar
Default Wiper Motor Re-assembly Woes Arm dips down before wiping.
Ok, I removed the wiper motor assembly to change the starter in my 1995 XJ6.
Starter changed, everything as it should be, no nasty bendix grinding noise = Great.
While reinstalling the wiper motor assembly, I ended up taking the internal linkage apart from the motor to ease installation.
Re-assembled and everything buttoned up. Reinstall wiper arm and test.
No good. The wiper blade now sits about 5 inches high on the windscreen. When turned on it dips down towards the cowl on the LH side before going the other way.
I thought I may be off 120 or 240 degrees with the 3 bolts, but the motor orientation is towards the LH side and downward, which google images show as well.
Is the orientation wrong or is there perhaps something I missed when re-assembly the whole thing?
Any insight or advice is appreciated.
No rain, so I took a 2 hour cruise, nice to have things quiet again.
Thanks in advance.
Old Jul 17, 2016 | 11:37 PM
aholbro1's Avatar
Hey Alan,
My $200 car does same thing. Motorcarman told me to take the cover off, lift out the internals, turn a notch or two and replace them. I had it inside a few months ago, and removed the 3-bolt cover, but couldn't budge any of the internals. Haven't had a chance to get back to Motorcarman and find out what I was missing. It still needs tires and a battery so wiper position is not yet near the top of the priority list...
Old Jul 19, 2016 | 06:19 AM
Ok, so I have it down to a mis-alignment of the Crank Arm that splines to the Wiper Motor. I neglected to mark it in place or to snap a picture.
Anyone have a photo showing this crank arm at the "home" or "off" / "rest" position? Or perhaps an easy way of getting the timing right?
Old Jul 19, 2016 | 03:12 PM
AL NZ's Avatar
My Daimler 6 does the same thing, and it's my fault
The wipers were perfect, then one day I pulled in for gas. The wipers were on intermittent, I put the gas nozzle in to fill , then went to wash the windscreen. As I started pushing the washer brush across the windscreen, the wiper arm swung across into it (I had forgotten they were on)
Since then it sits up about 4-5 inches above the correct horizontal resting position, but has a normal arc.
It was initially sitting higher - about 10 inches up - but I forcably pushed it back down. This took some brute force, and I thought I might break something, so at 4-5" I stopped...
jagsrule
May 6, 2016 07:08 PM
Wilfred88
Apr 14, 2016 02:10 PM
XKR8
Apr 12, 2016 07:17 PM
Zachsquach
Mar 30, 2016 11:04 PM
Kit1
22
Feb 15, 2015 06:01 PM
