x300 1995
Old Jul 2, 2010 | 08:32 AM
nigel's Avatar
Default x300 1995
hi i have just joined jag forum and i am looking for a little advise my jag was running fine one day the next day it wouldd not start . cranking but not starting i cant smell any fuel what would be most likley fault
Old Jul 2, 2010 | 08:44 AM
ken@britishparts.com's Avatar
Need a lot more information.
Old Jul 2, 2010 | 09:04 AM
nigel's Avatar
Default 1995 x300
thanks kenkarr for reply i have checked all fuses and relays also the switch under drivers fottwell i have also backed the nut of where the fuel goes into the fuel bar the outcome was no fuel coming through to the engine how do i check the fuel pump is working thank you
Old Jul 3, 2010 | 03:01 AM
bhmaxjag's Avatar
Pull the harness off the pump and check to see if it is getting power at ignition on and while cranking. If you're not getting power then your problem lies within a fuse, relay, or wiring.
If it does have power, then suspect a faulty pump.
Old Jul 3, 2010 | 07:48 AM
sparkenzap's Avatar
The X300 fuel pump is in the tank. The pumps are known to fail and there is a rubber hose secured by a screw clamp on the pump's outlet inside the tank that is known to come off. Test for current draw to confirm the pump is running. Either way, you must remove the tank for repair.
Old Jul 3, 2010 | 03:28 PM
nigel's Avatar
THANKS FOR YOUR SUGESTION ROSS IHAVE TAKEN THE TANK OUT TODAY AND REMOVED THE PUMP AND TESTED IT IN A BOWL OF FUEL IT WAS PUMPING VERY WELL I REPLACED ITALL AND THEN CRANKED THE ENGINE OVER AND GUESS WHAT ITSTILL WOULDENT START SO AT LEAST I KNOW THE PUMP IS OK HOWEVER I WOULD APPRICATE ANY MORE TIPS LIKE WHERE IS THE PUMP RELAY SITUATED ARE THERE ANY HIDDEN IN LINE FUSES OR IN LINE FILTERS THANKS AGAIN FOR YOUR HELP I DONT FEEL QUITE SO ALONE WITH MY NO START PROBLEM
Old Jul 3, 2010 | 04:01 PM
sparkenzap's Avatar
BTW, Nigel
The fuelm pump only pumps for a few seconds on crank until it sees continuous pulses from the ckps. What is your tach doing while you crank? If you do not see 2-300 rpm, then look for crank position sensor problem.
Old Jul 4, 2010 | 03:14 AM
madfred's Avatar
Default x300 starting
hi mate have checked ignition coils there is on on each plug just a thought
Old Jul 9, 2010 | 10:20 PM
bhmaxjag's Avatar
Do what I suggested originally and check if you're getting power down at the pump harness. You know the pump is good...so if you're getting power down to the pump as well then you know your problem isn't with fuel delivery (unless you have a VERY plugged up fuel filter).
3 major things you need for a vehicle to start and run...fuel, spark, and compression. Find out which you're lacking and we can help you further from there.
Old Nov 8, 2012 | 06:05 PM
Fredie's Avatar
I also have a 1995 X300 and have no fuel. I have got to a point where I have hot wired the fuel pump and can start the car so my guess is that the problem is a fuse of a relay.
can anyone help me with which ones to check.
Old Nov 9, 2012 | 07:30 AM
Roger95's Avatar
Check the crank shaft position sensor. A no start condition is a symptom of failure.
Old Nov 9, 2012 | 07:57 PM
Fredie's Avatar
Crank is fine as the car will start when I hot wire the fuel pump.
Can anyone advise me where to find the fuse and relay.
thanks Rob
Old Nov 9, 2012 | 10:51 PM
Suede's Avatar
The fuel pump relay is located in the trunk fuse box behind the battery. If original, it's blue in color.
Old Nov 12, 2012 | 05:13 AM
Fredie's Avatar
thanks for that. i changed all the blue relays in the boot to no avail so i changed the black relay and the car she goes. so i had another look as the socket looked burnt so i cleaned up the contacts and put the black relay back in and the car she go again.
So thanks again
Happy boy
Old Aug 10, 2016 | 11:08 AM
Andy Roo's Avatar
Hi I know i am several years after the first problem, but i too have a problem with starting x300 1994
My car cranks very well but wont fire 'check engine' warning light
i systematically swapped out the black relays in the engine bay , and then the blue ones in the boot even the black '423' one in the boot, car still wont fire.
Called the break down guy he squirted 'easy start' in the air line and car started but as soon as the turn off the ignition the car stops and wont start.
I bought a draper obd2 reader and gave error p1177 something to do with the fuel or maybe pressure..
Does anyone have anymore info on which relays need to be swapped
Old Aug 10, 2016 | 11:47 AM
44lawrence's Avatar
I read you checked ALL the relays ! At the advice of a forum member he advised me to check the 4 black relays on the passenger side (USA models) behind the headlight in the engine compartment. I think one is for the ECU, this one was my no starting/stalling problem on my 95 6cyl. I forget which one of the four it is but they are all interchangeable in order to switch around. . Also one is for the wipers. Don't know what the other two do. Anyway MAYBE this will send you in the right direction .
Lawrence
Old Aug 20, 2016 | 11:27 AM
44lawrence's Avatar
Check this X300 Forum page for this same problem . Thread is "96 X300" title. Four black relays behind right side headlight in the engine compartment.
Lawrence
mat32essex
Oct 3, 2015 04:12 PM
JaguarSV8
Oct 1, 2015 01:58 AM
280zx-turbo
Sep 28, 2015 04:37 AM
42Ajd
Sep 26, 2015 07:04 PM
