XJ6 phantom current draw
Old Jul 2, 2018 | 04:15 AM
Grahamgr's Avatar
Default XJ6 phantom current draw
1996 XJ6 LWB, 150,000km. Battery has suddenly started to go flat over a few days. Disconnected the battery and put an ammeter in series. Current draw is 0.07A, then every 30 secs or so, there is a 6A draw for a few seconds, then it falls away again. No lights on, ignition off, nothing running I can see. Any ideas where to start?
Old Jul 2, 2018 | 05:30 AM
Partick the Cat's Avatar
Sorry but you've posted in the wrong subforum. Your car is 1996 which is covered in the XJ 1995-97 (X300) subforum; this subforum is for XJs from 2003-09 (X350/358)
Old Jul 2, 2018 | 05:43 AM
Originally Posted by Grahamgr
1996 XJ6 LWB, 150,000km. .....
Welcome to the forum Grahamgr,
I've moved your question from X350 to X300 forum. Members here with the same model will be able to help.
Old Jul 2, 2018 | 08:21 AM
Lady Penelope's Avatar
When you pull the key out it makes a contact in the ignition switch from pin 4 to 5 providing a ground to command the Security Locking Control Unit to start the shutdown / go to sleep sequence , otherwise it stays alive . In this shutdown sequence you will see some current draw as it goes through the steps and go to sleep with a steady 30 mA draw thereafter . There are a couple of easy steps to take to ease through this one being the lubrication of the key barrel to make that switch contact and the other being to turn off the auto switch on the column for it's retract and tilt up potion of the shutdown sequence .
Report back with your observations and someone will assist you with deeper advice if needed .
In order that physics to be enjoyed it first must be obeyed .
Old Jul 2, 2018 | 09:41 AM
brian5's Avatar
I was reading the heading, and saying to myself, I have never heard of an XJ6 Phantom, is that a special edition for the US market?...................
I think they call that a senior moment.
Old Jul 2, 2018 | 09:50 AM
I call my Big Boy 4.0 liter AJ16 piston engine " The Thumper " as it pounds the torque out . And myself rebuilt starter " The Flamer " as it lights that baby off .
Old Jul 13, 2018 | 04:19 AM
Grahamgr's Avatar
Problem solved! I had installed some flash sheepskin seat covers on the front seats, and hadn't realised that one of them was catching on the electric seat controls and drawing current regularly. Feel quite foolish, but glad it wasn't a bigger problem.
This is is my first Jaguar and I am loving having a class car compared to my normal Japanese drive. Shame I won't be able to keep it beyond next year.
Old Jul 13, 2018 | 04:21 AM
Grahamgr's Avatar
Meant to say, thanks for your help n attempting to solve my problem. It wont be the last....
Digital Will
Feb 21, 2026 05:58 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Mar 3, 2007 11:37 AM
