xj6 starter
Old Apr 6, 2008 | 01:23 PM
RickSku's Avatar
Default xj6 starter
I just got a 95 xj6. My first jag. Anyway it won't start and I bought it that way. I charged the battery and the dash lights up but will not start or even make a soliniod noise. The guy I bought it from said it needed a starter. The car has 113 k on it. I would think a starter would last longer. I was trying to take the starter out (it is a straight 6) naturally the bottom bolt came out no problem. The top bolt is what I need help with. It looks like it goes in a different direction (top of bell housing)than the bottom bolt. I can see it but I can't get to it do I need to take anything off? What I am going to do is make a longer 13 mm box end (cut and weld)wrench and get it that way. Am I right in thinking that way or what. This car has some more issues but what the heck once I get it started it will be morefun.Glad to have found this forum.Any help will be deeply apreciated. Thanks Rick
Old Apr 7, 2008 | 08:35 AM
Frankie's Avatar
Default RE: xj6 starter
If you lower the tail end of the transmition it usually gives you enough room to get that bolt out.
Old Apr 8, 2008 | 04:16 PM
ken@britishparts.com's Avatar
It is very odd for those starters to fail. Bench test it before buying another unit.
Old Apr 8, 2008 | 08:07 PM
jag_genius's Avatar
it is rare but i have done about 5 or 6 .. that bolt can be seized sometimes.. at least up here in canada
davidboger
Oct 1, 2015 10:13 AM
baskervillema
Oct 1, 2015 01:59 AM
dansxj6
Sep 28, 2015 08:02 AM
42Ajd
Sep 26, 2015 07:04 PM
