xj6 upper front shock bushings
Old Sep 10, 2018 | 11:44 AM
xjfourty's Avatar
Default xj6 upper front shock bushings
hello,
there are 3 different kind of them on welshent, both part number CBC-5956
https://www.welshent.com/BUSHING-SHO...97-P11997.aspx
https://www.welshent.com/Urethane-Bu...nt-P25171.aspx
the second one is urethane made.
any advice on which one to buy ?
thanks
Old Sep 10, 2018 | 04:31 PM
Robman25's Avatar
Stay with the stock bushing would be my advice, less harsh and easy enough to change out.
Old Sep 10, 2018 | 08:23 PM
Lady Penelope's Avatar
There are different densities , softer for yours .Harder for the SC models
See link :
owerflexusa.com/xj6-x300-x3081994-2002.aspx
and :
https://blog.edgeautosport.com/break...hing-stiffness
Lower bushings are also suggested to change as I can see daylight through mine .
It's been suggested to stay with the original Jaguar part from the dealer as the others do not last long .
Old Sep 14, 2018 | 12:50 PM
xjfourty's Avatar
Called jaguar today the piece is discontinued... I will get the urethane one or I found somebody on ebay selling the original one hoping it's still in good conditions.
Old Sep 14, 2018 | 04:09 PM
xjfourty's Avatar
please correct me if I am wrong. Each side of the upper shock bushing has 2 bushings ? so I need total of 4 ?
Anyway I am not able to find the original jaguar ones. They are not available anymore.
Old Sep 14, 2018 | 04:49 PM
The original ones were recommended for the lower ones on the lower end of the shocks , my bad
the top end of the shocks take a total of 4 of the different part # as the tall donut shape .
I have not shopped for them
The ones for the rear as item # 17 :
https://www.jaguarclassicparts.com/u...-fittings-rear
The front ones apear to be item # 13 :
https://www.jaguarclassicparts.com/u...pper-and-lower
As to the quality of this product source is not known to me .
Old Sep 15, 2018 | 10:25 PM
Qvhk's Avatar
Incidentally I am fixing my front suspension system as well. I had genuine Jaguar insulation pad (Item 8) on the first diagram of Lady P's Post above (and see picture below),
but these factory pads while doing their job to ensure a quality ride, do not last as long as one would have liked, although longer than average after-market products. The mechanic knows some more durable ones which I am trying on.
As for other bushings, yes stay with factory originals if you can still find them. I have decided to go for Powerflex Purple and Black as it is easier to find a full set (and they have good diagrams showing you which is which) rather than hunting down on individual factory bushings as one or two are no longer available or you would have to go to different sources to find a full set. British Parts has the full set as well but those bushings do not last very long (9 months?). See pictures.
Old Sep 26, 2018 | 11:44 AM
xjfourty's Avatar
at the end I had my mechanic to install these since te original Jaguar ones are no more available
I really do not notice much difference compared to the old original ones (Which where so far destroyed) maybe slightly "harder/firmier" but I think they are good.
stevenx605
Feb 2, 2017 05:51 AM
Alvin Burns
Dec 2, 2015 04:16 PM
Rostman
Apr 9, 2015 03:47 PM
Dooley86
Dec 14, 2014 03:41 PM
ross1
Nov 20, 2013 04:19 PM
