“Trunk Open”...but not
Old Feb 29, 2020 | 09:17 PM
3timejag's Avatar
Default “Trunk Open”...but not
I recently acquired a 1998 XJ8 Vanden Plas. There is a separate key for the trunk only, so I’m assuming there have been issues previously with the lock. The Trunk Open light stays on and I would like to know where to start trouble shooting before I delve into pulling the trunk lock area apart.
Many thanks to All!....Best forum and members ever, no doubt.
Old Mar 1, 2020 | 09:47 AM
Highhorse's Avatar
Yeah, sounds like its been replaced and someone forgot to connect something or didn't align it. For a matching key setup, you may want to contact Sone and see if he can help... https://www.jaguarforums.com/forum/market/227433
Old Mar 1, 2020 | 10:59 AM
3timejag's Avatar
Thank you!
Old Mar 1, 2020 | 01:02 PM
Jhartz's Avatar
I had the same issue in my first 2001. Check the wiring that runs along the right hand side hinge in the boot. Mine was a shorted wire from the lock to the computer at the hinge.
Old Mar 1, 2020 | 02:15 PM
3timejag's Avatar
I will, thanks Jim, you’re always a great help.
Old Mar 7, 2020 | 10:53 PM
3timejag's Avatar
Test
Old Mar 7, 2020 | 11:01 PM
3timejag's Avatar
Okay, I posted that “test” because I tried a lengthy post here and it wouldn’t take, and I lost the type....
altight, I checked for frayed or broken wires in the trunk, at the hinge, and found nothing. While in there, I popped open the trunk liner and saw a little greenish connector that ran to the open button. I disconnected it, and that made the “trunk open” light go away....but it also caused my alarm to go off after about 3-4 minutes after I parked the car. Hmmmm. Okay, we’ll I reconnected it thinking the alarm issue would go away, but now the alarm goes off only if I lock the car. Leave it unlocked, and no alarm. I am starting to think it could be the security locking module?? Does that sound possible? All of my brake lights are fine and I say that because I’ve had brake light issues in the past on my other XJ8’s and the SLM was the issue.
Can a faulty SLM cause trunk light/alarm/lock the car issues as described here?
Many thanks in advance, I’m veery perplexed...
Old Mar 7, 2020 | 11:03 PM
3timejag's Avatar
Oh, and I can’t program my key fob, tried my known good one and no go...SLM?
Old Mar 7, 2020 | 11:38 PM
Highhorse's Avatar
Try a hard reset.
Old Mar 8, 2020 | 12:01 AM
3timejag's Avatar
I did before this alarm thing started, but I’ll try that again. So do you think the SLM could have anything to do with there issues as well?
Old Mar 8, 2020 | 08:02 AM
Highhorse's Avatar
Its possible...this is what sucks with 20 yr old electronics.
Old Mar 8, 2020 | 08:37 AM
3timejag's Avatar
I heard THAT! 😂
Old Mar 8, 2020 | 10:38 AM
motorcarman's Avatar
You need to look at the switch in the latch assy. They are the same for the X300 and the X308.
Boot lid open warning microswitch LNC6242AC
Old Mar 8, 2020 | 04:17 PM
3timejag's Avatar
I have purchased the micro switch and an actuator. Hopefully this will solve my problem(s).
Many thanks to everyone!
Old Mar 15, 2020 | 06:40 PM
3timejag's Avatar
update...I bought a micro switch and an actuator and installed them myself. Everything working now (it was the actuator), but now I can not for the life of me figure out where that micro switch should be seated! I have it hooked up, but don’t know where to secure it....can you help? Thank you for the suggestions as well!
Old Mar 15, 2020 | 09:01 PM
M. Stojanovic's Avatar
You should Google, a lot of info and pics can be found. This is what I just got searching for "Jaguar X308 trunk lock":
Old Mar 15, 2020 | 09:05 PM
Highhorse's Avatar
Surprisingly there are limited details on this....
(MS just got ahead of me on this)
Old Mar 15, 2020 | 09:15 PM
3timejag's Avatar
I was Googling “1998 xj8 micro switch location”, and similar terminology...no results...but then again I had forgotten it went on the latch.
Thank you!
Old Mar 15, 2020 | 09:18 PM
3timejag's Avatar
Yeah, I didn’t see anything either and of course had I remembered it went ON the latch, well, I wouldn’t have needed this information/picture(s).
feeling kinda dumb right now😂.
Thank you so much!
Old Mar 15, 2020 | 09:24 PM
3timejag's Avatar
Bonomassa one of my favorite artists, this is killer! This guys my favorite...
