02 jag xj8 jack stand points
Old Apr 11, 2020 | 11:29 AM
  #261
Mrjay622's Avatar
See...lol. I'm not completely out of my mind....
Old Apr 11, 2020 | 11:30 AM
  #262
Highhorse's Avatar
I may need to revisit because mine being a SC, it may be different?
Old Apr 11, 2020 | 11:31 AM
  #263
Highhorse's Avatar
Do you have either dots or a line mark on the face of the balancer?
Old Apr 11, 2020 | 11:33 AM
  #264
Mrjay622's Avatar
If I need a pipe not a problem.
Old Apr 11, 2020 | 11:35 AM
  #265
Carnival Kid's Avatar
Definitely no keyway there! So you passed the Saturday Morning Observation Test! LOL
It is a little unusual that the harmonic balancer is not specifically aligned, but hey this is Jaguar, so we shouldn't be surprised.
Old Apr 11, 2020 | 11:37 AM
  #266
I have to go and do some lawn mowing, will check back later.
Old Apr 11, 2020 | 11:38 AM
  #267
Mrjay622's Avatar
Wow.. I passed something...
thanks guys.
Ill look again for any alignment marks.
Maybe that's why others said use a bolt or pry bar to hold the flywheel?
Old Apr 11, 2020 | 11:39 AM
  #268
Mrjay622's Avatar
Come on the grass will still be there tonight!
This is more important!
Old Apr 11, 2020 | 11:47 AM
  #269
Highhorse's Avatar
Not if Mint Sauce gets to it... lol
Old Apr 11, 2020 | 11:56 AM
  #270
Highhorse's Avatar
This is direct from Blackonyx's detailed removal/install and it does not specify like all the other instructions.
MM. Refit crankshaft pulley:
1) As when removing the pulley you need to keep the crankshaft from rotating. I used pry bar between the drive plate and torque converter with the handles supported with a jack to keep it from moving.
2) Place some form of shield behind the radiator to protect it
5) Remove front crankshaft seal protector
6) Put a good amount of grease on crankshaft seal
7) Install a new o-ring on the pulley. Apply some grease to the o-ring.
8) Install the crankshaft pulley
9) Install the split lock ring on to the crankshaft
10) Install the new crankshaft pulley bolt
11) Make sure that the crankshaft setting tool is removed from the torque converter.
12) Tighten the crankshaft pulley bolt (24mm 6 point socket (15/16" will also work)) to 364-386 Nm
13) Remove your method of securing crank.
14) Reinstall the two covers on the torque converter housing.
Old Apr 11, 2020 | 12:05 PM
  #271
Mrjay622's Avatar
Morning HH
I read that too... I'm not seeing much of anything there expect the metal the the tool was locked into... hell I try it.
I also don't see the flywheel teeth as others have mentioned for the pry bar.
I should buy a flashlight these matches are burning my fingers!
Old Apr 11, 2020 | 12:17 PM
  #272
Mrjay622's Avatar
No markings..
everything is out of order. ..
Old Apr 11, 2020 | 01:24 PM
  #273
Highhorse's Avatar
The flywheel teeth are on the back of the motor on the flywheel....for your starter to start the car....silly boy... ...do I have to have Mint Sauce show you this...lol
Old Apr 11, 2020 | 02:34 PM
  #274
I would not recommend using the flywheel teeth to hold the crankshaft, once the harmonic balancer has "grabbed" the tapered collet you will be able to use the large crankshaft holding tool to tighten the crank bolt.
Back to the mowing and leaf burning.........................
Old Apr 11, 2020 | 04:38 PM
  #275
Mrjay622's Avatar
My poor buddy everyone gives him a hard time especially store managers!
I found the access to the flywheel and I see the back side of the studs to the converter.. Just couldn't get a pry bar or anythingelse to hold or stay in place, I even tried using a jack.. after a few times back and forth I gave myself and break and started burning branches also...
Bob's Growing and learning how to attack So look out....
Less than 24 hours old. On January 30th
Today . He's mowing the lawn. . He has along way to go.
His own hay field..
everything passed the trees is alfalfa hay
Old Apr 11, 2020 | 04:45 PM
  #276
Mrjay622's Avatar
Just because my parents called me their special boy doesn't mean I didn't learn somethings...lol
Also i wouldn't of used the flywheel teeth to hold the crankshaft. It was something I read that others have done....
That's why I came to you guys...
Old Apr 11, 2020 | 07:25 PM
  #277
Mrjay622's Avatar
Ok i did what HH suggested it's all gooped up with BJ Weird waiting for it the cure.
Thanks. HH
Old Apr 11, 2020 | 07:26 PM
  #278
Mrjay622's Avatar
. Bob wrote that....
Old Apr 12, 2020 | 03:53 PM
  #279
Mrjay622's Avatar
Hi guys .. Happy Easter.
ok that headache is over....
Old Apr 12, 2020 | 06:21 PM
  #280
Highhorse's Avatar
Lookin' good...
