1998 Jag xj8 tilt motor replacement
Old Sep 27, 2020 | 10:40 AM
stan61's Avatar
Default 1998 Jag xj8 tilt motor replacement
Good Morning group, I am attempting to replace the tilt motor on the above mentioned car. I removed the old motor, but I am having a heck of a time getting the new unit installed. Any tips or advice is greatly appreciated. The alignment of the actuator into the motor coupling is my main problem. Do I have to drop the steering column to finish this project. Thank you for any advice.
Old Sep 27, 2020 | 01:49 PM
motorcarman's Avatar
I always plug the motor assy (mechanically disconnected from the column) into the car an run the motor UP until it stops.
Then 'hand-twirl' the column plastic male drive end to the max height and back off 1/4 to 1/2 turn.
Slide the plastic drive coupler together and level the motor assy until you can install the 2 screws. (I use a long 4mm ball end Allen 3/8" drive)
If you do not set the UP end point, the motor will not know where the upper limit is and try to drive past the mechanical stop.
Old Sep 28, 2020 | 03:19 PM
stan61's Avatar
Thank you Motorcarman, you description will help me get this thing back together. One issue I was having was lining up the bracket for the wire connectors to be hung on, and trying to get the bolts started at the same time. but I will get back at it tomorrow, I'll have the whole day to tackle it. I have to say again, this Forum is a great way to get advice and information. thank you again.
Johnken
Jun 17, 2015 05:08 PM
Johnken
Apr 12, 2015 05:18 PM
theJPster
Jan 23, 2012 08:26 PM
michaeldoherty
Dec 19, 2009 05:24 AM
