1998 Supercharged XJR Potential Mods
Old Jun 29, 2023 | 12:18 PM
luke.mitchell's Avatar
Default 1998 Supercharged XJR Potential Mods
Hello, I’m mostly just sorta curious not planning on doing much yet, but I was wondering what mods you could do to the 1998 XJR with the supercharged v8 to reduce the 0-60 time. Thanks for any answers you can provide!
Luke
Old Jun 29, 2023 | 12:44 PM
nilanium's Avatar
Avos twin screw kit
Shorter ratio 15HU LSD out of an x300, also to help avoid blowing up the stock 14hu
LS swap with a manual?
Those are really the best options if you want to make a meaningful improvement
Old Jun 29, 2023 | 12:49 PM
Originally Posted by nilanium
Avos twin screw kit
Cool, thanks. I’ll keep it mind!
Old Jun 29, 2023 | 05:18 PM
Quadcammer's Avatar
With stock head gaskets not much. Intake tube and maaaaybe a 6% upper pulley
Old Jun 29, 2023 | 05:20 PM
Alright, thanks!
Luke
Old Jun 29, 2023 | 11:18 PM
Addicted2boost's Avatar
I’m not trying to be pessimistic but realistic with you. Assuming your engine is original to the car and the heads have never been off, the next mod to do to the engine is a fresh valve job and new mls head gaskets. Until that happens, don’t mod the car as milkshake is in your future even in stock form. The stock fiber head gaskets were weak.
Old Jun 30, 2023 | 07:40 AM
All good! Thanks for the warning.
Luke
Old Jul 1, 2023 | 10:30 AM
vincent661983's Avatar
Let me say a few things but please understand nothing means to offen anyone.
If you are after the 0-60 time. This SC 308 is not for you and it's not even a good platform for that.
All performance upgrades are very expensive and require tones mechanical works.. a lot of things are off one and you would not find any plug and play parts from vendor.. also pretty much other parts would require also replacement... Overhaul......
​​​​​​do expect over budget...last minute technical problem discovery....over estimate labor time....
Old Jul 12, 2023 | 06:41 PM
SteveM's Avatar
Mine were fine with 10 years of 500+ hp.
Noma Auto Parts
Jun 6, 2023 05:18 PM
GerryXJR
Feb 18, 2013 08:42 AM
Ipc838
Oct 4, 2012 04:06 AM
