1998 XJ8 Transmission cooler line leak
Old Aug 24, 2012 | 07:33 AM
scrimshank's Avatar
Default 1998 XJ8 Transmission cooler line leak
I need to repair damage to the lower transmission cooler line on my 98 XJ8.
Research on this forum suggests that the transmission lines cannot be removed without lowering the steering rack - at a minimum. Can anyone who has done this job confirm that this is correct? What about the option of cutting and removing the old line, and replacing it with a fabricated high pressure flexible line? Thanks for any insights.
Old Aug 24, 2012 | 08:41 AM
motorcarman's Avatar
I have repaired a trans cooler line that had a spot rubbed/chaffed from a PAS hose. I cleaned the area with solvent and cut a piece of rubber fuel line and split it so it would fit over the leak. I applied some RTV oil pan sealant and clamped it in place.
No more leak!!!!!!
It may work for you?? It depends on how large the hole is, if you can clean the area properly and the quality of the repair.
There is not much pressure in the line to/from the cooler.
You might even get an in-line filter kit to splice in that spot to serve as a repair and additional filter.
bob gauff
bamforp
Aug 14, 2024 05:36 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Rlover
Mar 30, 2016 10:04 PM
sogood
Sep 15, 2015 07:35 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
