1998 XJ8L: ABS, Traction, & Stabilty Control Lights On
Old Dec 16, 2012 | 06:23 AM
FreeTime's Avatar
Default 1998 XJ8L: ABS, Traction, & Stabilty Control Lights On
I recently putchased a 1998 XJ8L that Im in the process of bringing back to road worthiness. The car is relly clean but needed a few things, mainly suspension related.
I have replaced all the front suspension bushings, sway bar ends, shocks, etc. I also did the rear shocks. This has made a huge difference and its now great to drive.
My Traction control and stability control lights are on however. ABS light is also on.
The guy you owned before me had a dirt driveway and everything had a pretty good amount of dust and mud but I have everything clean now.
Any direction you guys could point me in for diagnosing, testing, repaing this next project would be very appreciated.
Thanks,
Dave
Old Dec 16, 2012 | 08:21 AM
Highway Star's Avatar
Default Code Reader
Hi Dave,
if trying to fix it on my own the first thing I would do is to get an ODB II code scanner. The fault code read from the car's fault memory provides more details on the problem. For example, which sensor might be faulty.
Old Dec 16, 2012 | 09:37 PM
sparkenzap's Avatar
You WILL get some quick help in the X-308 forum section
Old Dec 17, 2012 | 06:06 AM
RJ237's Avatar
I just sent this to a XK8 owner, and I think it applies to your car also, from jagrepair.com.
You can check each wheel circuit at the connector, but I think you will find 1100- 1200 ohm, not 2000+. Disconnect the neg. battery cable before removing the connector.
http://jagrepair.com/images/AutoRepa...heet%20XK8.pdf
Old Dec 17, 2012 | 07:22 AM
rocklandjag's Avatar
RJ- You are correct. I recently had a problem and my ABS light was lit and the "traction control not available" message was on. My reading was 1134 for the left side sensor but way out of whack for the right side sensor. The problem on mine was the connection of the wiring harness where it plugs nto the sensor and after fixing the connection the reading was then 1131 ohms for the repaired sensor.
Note: the ABS light stayed on at start-up even thought the "traction control" message was now off. The ABS light went off after driving a short distance so be sure to drive the car after any trouble shooting to see if the problem is resolved.
Old Jul 17, 2014 | 02:14 PM
echoharper's Avatar
Stop messing around remove the abs module easy once you bend the metal tubes out of the way, remove the washer fluid fill tube (!/4 turn) and send off on ebay with 50 bucks 30 minute total job
Old Jul 17, 2014 | 03:31 PM
RJ237's Avatar
That's good advice if he knows the abs module is faulty, but wasted money if it's a dirty sensor, bad connection to the harness or a broken harness wire.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
pocketrocket
Sep 3, 2015 07:44 PM
innzane
Sep 2, 2015 10:08 AM
