1998 XJ8L-Trunk button does not work
Old Jan 7, 2008 | 03:11 PM
97Aggie's Avatar
Default 1998 XJ8L-Trunk button does not work
I am new to this forum, but would certainly appreciate some help. I have had this XJ8L for about a year and a half now and love it. About 6 months ago the button on the remote stopped opening the trunk. I replaced the battery but it was not that. From there I noticed that none of the buttons, including the one on the trunk itself, will open it. Now I have to manually open it with the key. Just wondering if anyone has had this problem. I have looked for bad fuses, but have not found any.
Thanks.
JP
Old Jan 7, 2008 | 03:55 PM
ken@britishparts.com's Avatar
Default RE: 1998 XJ8L-Trunk button does not work
Check the valet switch. I believe it is in the glovebox. Might want a second opinion on where the switch is located.
Old Jan 7, 2008 | 05:31 PM
jag_genius's Avatar
not in trunk . on center console.. open your trunk and see if your trunk lights work ..and ill give you the answer.
Old Jan 7, 2008 | 06:24 PM
97Aggie's Avatar
Yes. My trunk lights still work just fine.
Old Jan 8, 2008 | 06:23 AM
97Aggie's Avatar
One other thing. I do not believe that it is the valet button/switch. I know that when it is in "valet" mode, when you hit the trunk release button that is in the car, it makes a chiming sound. This makes no sound, just does not work. The button in the car does nothing, the remote does nothing, and the button on the trunk does nothing. Any suggestions?
Thanks.
Old Jan 8, 2008 | 06:01 PM
jag_genius's Avatar
well if the trunk lights work when opend then the problem is in the trunk actuator or wiring... right side of trunk lid..
Old Jan 9, 2008 | 07:06 AM
97Aggie's Avatar
Thanks. I will continue to check wiring in the trunk.
Old Jul 6, 2010 | 06:50 PM
roswellman's Avatar
I have same problem but my lights do not light up when I open trunk with key?
Old Jul 6, 2010 | 06:51 PM
roswellman's Avatar
Any help would be greatly appreciated
Old Jul 7, 2010 | 07:46 PM
Sarc's Avatar
@roswellman
You more than likely have the same issue jag_genius suggested, ie damaged wiring on the wiring loom running down the right hand trunk lid..... strip it back and take a look
(All of the trunk features are dependent on this single wiring loom and it wears with time. The faults can be no trunk lights, no remote trunk unlock, trunk open warnings on the dashboard info centre...)
Old Jul 7, 2010 | 09:05 PM
Rae's Avatar
Rae
I agree with jag_genius & SARC, I had the same problem 99xj8, dealer said it was the wiring harness $400 item, I passed & use the key.
jag_genius & SARC: I have a partial spare harness from a trunk lid I replaced. What do you think about isolating the actuator wire and splicing in a section from near the plug to the actuator...?? Thanks RAE
Old Jul 8, 2010 | 06:09 AM
roswellman's Avatar
Default Trunk does not open
Thanks for trhe info on the harness it had two wires broken about 4 inches back
Thanks again
JarodL
Mar 7, 2024 01:39 AM
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
jehart49
Sep 12, 2015 05:36 PM
arnoldmilk
Sep 3, 2015 07:42 PM
