1998 XJR diff internals swap
Old Oct 26, 2021 | 03:06 PM
Per's Avatar
Per
Question 1998 XJR diff internals swap
The diff in my XJR is dead. It turns out this is a common issue as the 14HU diff is weaker than its forebears while the power and torque it has to handle is greater. So broken teeth rattling around is the issue. I therefore want to swap the internals if possible. I have read that DANA 44 internals will fit straight away. But will the pinion from DANA take the flange for the Jurid / Hardy coupling? If not the prop shaft will have to rebuilt. And so on....? And what are the actual DANA part numbers?
Further I want to add LSD, will Quaife still fit DANA (pinion and) ring gear? It should, but then again...... Any alternatives to Quaife? Torsen?
Old Oct 28, 2021 | 07:05 PM
Highhorse's Avatar
The one member I know that can answer that and he is Count Iblis. He has done the Dana retro. You may wish to contact him about pricing.
Old Oct 28, 2021 | 07:11 PM
xalty's Avatar
the way he did it is very expensive. much cheaper and easier ways to do it
Old Oct 29, 2021 | 04:06 AM
Per's Avatar
Per
Is there an LSD that will fit 15HU factory pinion and ring gear? I am confused about which period Jaguar did not supply LSD. The word is that in order not to outdo Aston Martin DB7 Jaguar were not allowed to fit LSD to the XK8 in any variety. And therefore XJR was not allowed either.
Old Oct 29, 2021 | 07:20 AM
Highhorse's Avatar
Yeah, I know, but he is the only one I know that's done it.
As for myself, I'd like to get a diff out of a 2012 and newer Mustang. They come out of the factory able to handle over 500hp.
Old Oct 29, 2021 | 07:47 AM
xalty's Avatar
all xjr6, some xj40s and late xjs v12. they need new clutch packs though or you will have a one tire fire
or you can drill out a new 19 spline d44 limited slip carrier holes to 10mm and bolt the 15hu ring gear to it. either the auburn cone or the speedmaster torsen type.
https://www.speedmaster79.com/DANA-44-19-Spline-3.73-and-Down-TorqueWorm-LSD-Limited-Slip-Differential
Old Oct 31, 2021 | 11:39 PM
Vauxi's Avatar
What breaks in HU15 ? Diffrential small gears? If so by replacig them with quaife locker what is mafde for xk8 should do the trick ?
Quaife
Didnt't xk8 use same hu15 diff as xj8 ?
Old Nov 1, 2021 | 02:51 AM
XJR-99's Avatar
Quaife
I guess you mean 14HU. It's just 8" and was never enough strong for supercharged. The angle between pinion and crown wheel is wrong. Too much load for a few teeth.
Older, a step stronger 15HU is 8.5". Shot peening ans some cryo treatments of stock internals makes them more cacable to take that load.
I have broken both, 14HUwith Quiafe ( two broken pinion teeth ) and now stock 15HU with L ( not yet opened , but sounds like same problem ).
Old Nov 1, 2021 | 05:38 AM
Per's Avatar
Per
Having looked at the specs for xj40 and x300 it looks like none of the 15HU diffs had 3.06 ratio? Is that correct? That means somehow fooling the gearbox control unit to avoid limp mode (the sequence done at every journey start referred to in another thread is not for me, I want something simpler). I have searced for the ford electronics box for fool fooling the TCM in the ford performance catalogue but found nothing.
Old Nov 1, 2021 | 06:51 AM
xalty's Avatar
@Chirpy already made a canbus signal modifier and somebody has already used it for their swap. you can have any ratio you want
not needing to match ratios means use you can use a 15HU ring and pinion, save money and have better gearing anyways
Old Nov 1, 2021 | 07:12 AM
Vauxi's Avatar
Oh yes. 14HU.. Mornings.. Okay pinion gear goes. Then locker isn't the fix.
Peter Brock
Mar 31, 2021 08:48 PM
Willafizz
Jan 21, 2021 01:41 PM
Col. Sandurz
Jul 6, 2017 10:14 PM
popeye68
Oct 7, 2011 09:33 AM
driver safz
Sep 17, 2011 05:25 PM
