1999 xj8 massive battery drain
Old Aug 20, 2016 | 06:20 AM
marky151's Avatar
Default 1999 xj8 massive battery drain
Hi, have a pretty big problem with a parasic battery drain, in fact huge!!, drain test shows 6.96AMPS!!!, disconnected alternator down to 4.56AMPS so still have a massive drain, had alternator bench tested and its ok, also shows ECU is still powered up when key out of ignition. HELP any ideas? Cheers Mark
Old Aug 20, 2016 | 07:27 AM
jimbov8's Avatar
Check the little flap in the ignition is closing when you remove the key.
The alarm chirp sounder, behind the right front wheel arch, maybe grounded.
Make sure all courtesy lights are turning off.
Following that, if you still have the problem, isolate each main fuse box in turn.
Old Sep 3, 2016 | 06:20 AM
marky151's Avatar
Just to give an update, Fault FOUND, was the alarm sounder, pulled 10amp fuse in engine bay fuse board and the drain went away and car working fine, weird as the alarm warning and the alarm works fine so wondering what sounder fuse that was. Thanks Jim for the pointers!!!!
Old Sep 3, 2016 | 06:22 AM
jimbov8's Avatar
Glad to be of help.
ohnoesaz
Dec 5, 2018 10:31 AM
yidal8
F-Pace (X761) / C-X17
Jul 26, 2016 08:16 AM
Chris starko
May 14, 2016 11:31 PM
Ronco1
General Tech Help
Apr 21, 2016 12:37 PM
thetruthc32
Aug 16, 2007 08:03 AM
