1999 XJ8 problems starting!
Old Jan 9, 2008 | 06:18 PM
jag_genius's Avatar
Default RE: 1999 XJ8 PROBLEMS STARTING!
does it crank over or do you just get dash lights on and errors when the key is turned?
Old Jan 10, 2008 | 05:32 PM
jag_genius's Avatar
sounds just like a dead battery ... the stability control error is from voltage to low.. check ur battery ..or it cud be a loose or corroded or burnt power studs which is very common.
Old Jan 10, 2008 | 10:20 PM
drog321's Avatar
i had a bunch of crazy electrical problems that had 2 mechanics tell me they'verarely seen these problems, and they eluded that it was going to be a very expensive repair because it would take a lot of trouble shooting. It seemed like the problems happened right after i added a radar detector and the forum people thought that was the cause and not just a coincidence.
issues
a)traction control failure - it would get thrown almost always at low speeds
b)car stalled sometimes, typically at low speeds or while stopped.
c)the car alarm and all other electricalaccessories (such as the trunk)would sometimes not work after turning the car off - also the car wouldn't restart...normally after about 10-15 minutes, then it would finally work. I found myself tied to my car at the airport while waiting for a flight, and my girlfriend had to take a cab from my car to a job interview after she stopped for coffee....not fun
fix
replacing the battery cut the frequency of these issues down 80%. I was made aware the voltage was off on the alternator, and it was suggested i replace it. On my way to take the car in, i was .5 miles away from Ken's Austin British Motorcarslocation, and the belt to the power steering broke along with the tensioners. Replacing the tensioners and belt fixed all of these problem listed above, also my car ran smoother.
DR
Old Jan 14, 2008 | 01:00 PM
drog321's Avatar
orca99usa,
what dothe throttle plate and the plenum cover look like?
pardon my ignorance...i'm more comfortable playing around with the interior of the car, versus working under the hood....
Old Jan 14, 2008 | 02:15 PM
FactoryJaguarTech's Avatar
Follow the tube from the air filter. Two 8mm bolts hold it down onto the throtle housing. Clean the plate under it. Remember to put the rubber seal back on the tube when you done.
Old Jan 16, 2008 | 05:16 PM
jag_genius's Avatar
if it wants to start and it cranks then it may seem to be flooded .. put your gas pedal to the floor and crank this shuts off fuel .. and when it starts to fire release the gas pedal allowing fuel to flow.
Old Jan 27, 2008 | 06:54 PM
Hah! Genius, gotta love it.
Old Jan 28, 2008 | 07:03 PM
jag_genius's Avatar
YEP!
Old Apr 6, 2014 | 09:32 AM
maximus123's Avatar
i just put a timing chain in my 1999 xk8 it was fine for 100 miles now the engine fail safe light transmission fault and the stabilization are all blinking does anyone know the problem? tx maximux123
Old Apr 6, 2014 | 02:33 PM
sparkenzap's Avatar
Read the codes!
thedugger1
Sep 24, 2015 05:32 PM
1964Daimler
Sep 2, 2015 11:41 PM
casepie
Aug 30, 2015 09:49 PM
bigw909
Aug 30, 2015 09:29 AM
souldoubt
Aug 25, 2015 08:15 PM
