1999 XJR heater hose replacement
Old Mar 8, 2015 | 03:03 PM
evergreen's Avatar
Default 1999 XJR heater hose replacement
Help! I have a leaking cooling hose under the supercharger on the right side. How big of a job is this to repair and replace? Can't find a repair manual at the local parts shops or the dealer. Any ideas would be great.
Thanks in advance.
Evergreen
Old Mar 8, 2015 | 03:06 PM
Cambo's Avatar
XJR, or XKR?
Old Mar 8, 2015 | 03:39 PM
evergreen's Avatar
Default 1999 xjr
Sorry again it's a 1999 XJR.
Old Mar 8, 2015 | 06:17 PM
Welcome to the forum evergreen,
I've moved your question from General Tech Help to X308 forum and edited the thread title to the correct model information. Members here with the same model will be able to help.
Old Mar 8, 2015 | 06:54 PM
RJ237's Avatar
The workshop manual JTIS21 is available as a download in a Sticky, but you need 10 posts and s few days membership before you can download. i believe it has also been provided on mediafire and some one may be along to help you find that.
You will need to remove the supercharger to replace the heater hoses.
Old Mar 8, 2015 | 07:06 PM
motorcarman's Avatar
Just the throttle assy and supercharger are required to get to the heater supply and return hoses. (please replace BOTH)
You don't need to remove the intake heat exchangers or injector/lower intake.
The thermostat housing assy will need to come off to remove the S/C.
bob gauff
Xj812
Oct 26, 2015 05:04 AM
Sprayall
Sep 3, 2015 07:49 PM
big d
Sep 3, 2015 07:37 PM
casepie
Aug 30, 2015 09:49 PM
bigw909
Aug 30, 2015 09:29 AM
