2 sizes for the front sway bar links
Old Mar 15, 2013 | 06:11 PM
rocklandjag's Avatar
Default 2 sizes for the front sway bar links
I just replaced my front sway bar links (2nd time) and found the first set that I had installed are about 1" shorter than the new links. I dug out the ones that were on the car when I got it and they are also the longer ones. The brand new links are URO Parts #MNC2105AA.
Are the new longer links the correct ones?
Old Mar 15, 2013 | 06:21 PM
plums's Avatar
The part number is correct for your '01. No idea if it is actually the correct part.
Old Mar 15, 2013 | 06:54 PM
With the car up on jacks stands and the shorter links installed the ends ofthe anti-sway bar are parallel to the chassis and with the longer ones the baris angled upwards about 20 degrees
Old Mar 15, 2013 | 06:58 PM
plums's Avatar
parallel would make more sense from a geometry standpoint ... guess you need to find out for sure whether the longer ones are just whatever uropart figured would fit.
"one inch longer" isn't going to allow anyone to help you. "the short one is X inches long from this point to that point" would let someone measure theirs and get back to you.
Old Mar 16, 2013 | 07:17 AM
good suggestion Plums - thank you.
The longer one is 6-3/4" tip to tip and the shorter one is 5 - 11/16" tip to tip
Old Mar 16, 2013 | 08:42 AM
JgaXkr's Avatar
Is it possible that someone installed a used spindle from an early XJ8? The early cars had smaller front wheel bearings & when they failed we installed a hub kit which had the later larger bearings & a different sway bar link. Just a thought.
Old Mar 16, 2013 | 09:35 AM
JgaXkr - thank you for the suggestion. I believe the spindles are original. I changed the driver's side wheel bearing a while back and it has the larger bearing
Old Mar 16, 2013 | 02:27 PM
GerryXJR's Avatar
Seems to me that the shorter links would provide better tension on the sway bar thus better "stiffer" controll to sway....
I wonder if the shorter ones are for an XJR?
Old Mar 16, 2013 | 02:44 PM
plums's Avatar
No. Only one number listed for all models on the front. But, 3 numbers depending on VIN.
Old Mar 16, 2013 | 02:45 PM
plums's Avatar
Hopefully someone comes along who happens to have their car up in the air.
Old Mar 16, 2013 | 04:51 PM
I took a picture with the car parked in the garage. The anti-sway bar is 13 -3/8" off the floor measured where the link bolts into the bar. I have 17" wheels on my car
Old Mar 18, 2013 | 04:23 PM
Could someone measure their anti-sway bar link so I can tell if I have installed the correct parts?
Thanks in advance
Forcedair1
Sep 8, 2025 01:57 PM
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
bamforp
Aug 14, 2024 05:36 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
