2000 xj8 crankshaft pulley removal
Old Aug 29, 2016 | 08:04 PM
pedromechani c's Avatar
Default 2000 xj8 crankshaft pulley removal
Hello my jag family,i am replacing my timing chain and all hardware. I've removed everything up to the crankshaft pulley ive manage to removed the pulley bolt and is stuck on the pulley. Any ideas would be greatly appreciated. Thanks in advance
Old Aug 30, 2016 | 05:53 AM
Highhorse's Avatar
Its a press on piece on a key, so it just doesn't pull off. You'll need a puller, probably get a loaner from Autozone or O'reilly's. But once it starts, it comes rather smoothly. You'll need to lock your crank into position and cams so as not to loose time. Do a review of 'tensioner replacement' or 'timing chain replacement'. There's a detail in here using the Site Search... JagRepair.com - Jaguar Repair Information Resource ...from black onyx. Or do a search on site here, there are 10's of threads on this procedure.
Old Aug 30, 2016 | 08:59 AM
motorcarman's Avatar
Here it is again.
bob
File Type: pdf
Old Aug 30, 2016 | 09:59 AM
dsnyder586's Avatar
One thing a user noted a few weeks back was that if you get the pulley and cone to move just a little bit, you may be able to tap the pulley back towards the engine and pop it loose.
Old Aug 30, 2016 | 07:47 PM
That IS the way it is supposed to be released/removed!!!!! It is all in TSB 303-10.
"move the damper and collar 1 to 2 mm forward on the crankshaft."
"Remove the tool from the damper and then pull the damper forward and off the crankshaft: if necessary, lightly strike the damper to loosen it."
bob
Old Aug 30, 2016 | 11:04 PM
dsnyder586's Avatar
Thanks Bob- I didn't know that for the first 8 times... Now I know and will do it right the next time.
wa3ra
Apr 12, 2016 07:40 PM
byjosh
Apr 1, 2016 02:11 PM
Feb 19, 2008 06:58 PM
Apr 2, 2007 11:08 PM
Mar 13, 2007 12:07 PM
