2000 XJ8 motor swap
Old Feb 25, 2015 | 05:46 PM
messiebess's Avatar
Default 2000 XJ8 motor swap
will a 2003 xjr (supercharged) motor be an easy swap into a 2000 xj8 - if not what motors are interchangeable with the 2000 xj8
thanks for any help
Old Feb 25, 2015 | 06:11 PM
test point's Avatar
It certainly will not be a direct swap. Easiest description is that you can reuse the short block. It would be much easier to find an AJ27 engine. That is the '99 - '02 XK8/XJ8. The '03 XJ8 4.0L will also work but the model year varies with your location.
Old Feb 25, 2015 | 07:28 PM
motorcarman's Avatar
As test point says..............
The problem with the Supercharged engine block is that the pistons are 'dished' to lower the compression ratio. You will not be happy with the lower power. The SC engine also lacks the VVT so you will be swapping MANY components.
Leave the supercharged engines for the supercharged cars!!!!!!!!!!!!!!
bob gauff
Bcrary3
Sep 12, 2021 05:41 AM
corysansburn
Sep 10, 2015 06:15 AM
AtholC
Sep 9, 2015 09:07 PM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
