2000 XJ8 Transmission Fault Light
Old Sep 14, 2016 | 09:08 PM
Brianna Renee's Avatar
Default 2000 XJ8 Transmission Fault Light
So let me start at the beginning. Restricted performance came on at one point or the other and had the code checked for the check engine light and it said "Cylinder 6 Misfire". Tried a spark plug change as a quick fix. Stayed the same. Tried changing coil 6 and coil 2 to see if it was the coil. Stayed the same. Then recently, Transmission Fault light came on and the car will go into reverse just fine but won't go into drive. In drive it is really sluggish and doesn't really accelerate. It revs up just fine. Could the transmission be crapping out as well or is it just shutting down to prevent further cylinder damage? Any ideas?
Old Sep 15, 2016 | 06:37 AM
Partick the Cat's Avatar
If your car is a 2000 XJ then it's an X308 (1997-2003) and unfortunately you've posted in the wrong sub-forum; you should post in XJ XJ8 / XJR ( X308 ) - Jaguar Forums - Jaguar Enthusiasts Forum
This sub-forum is for the X350/X358 model which ran from 2003 to 2009.
Old Sep 15, 2016 | 11:28 AM
I've moved this from the X350/X358 subforum to the X308 subforum
LoganR
Sep 7, 2016 11:26 AM
JimC64
Sep 3, 2016 08:20 PM
xtypejag502
Aug 27, 2016 09:18 AM
new2jag2016
Aug 27, 2016 01:02 AM
keelak
Aug 26, 2016 07:58 PM
