2000 XJ8 Windshield Washers
Old Mar 25, 2012 | 09:30 AM
CWigleyjr's Avatar
Default 2000 XJ8 Windshield Washers
Hi, Can anyone tell me how to remove & re-install the windshield washer resevoir on my 2000XJ8 ? The lines are clear and the resevoir is full but I can't hear the pump running when I push the button. Checked fuses & they seem fine. Not sure about any relays involved. Any guideance will be greatly appreciated.
Thank You,
Old Mar 30, 2012 | 11:38 AM
CWigleyjr's Avatar
Am I in the wrong place for this question. Being a newbe, not real sure where to list this question. Really need to have some help on this one before I do something wrong trying to get to the windshield washer resevoir. Thanks guys, need your help.
Old Mar 30, 2012 | 04:21 PM
Stu 1986's Avatar
You need to remove the chin tray under the front bumper and the RH wheel arch liner. It is best to remove the front wheel, from there you will be able to get at the motor. It is likely that it has just given up the ghost, very easy to replace. Hope this helps.
Old Mar 30, 2012 | 08:23 PM
jimlombardi's Avatar
Hi
I extracted the Windshield Washer Pump removal & install from the Jaguar shop manual and created this PDF file:
XJ [X308] Windshield Washer Pump R&I.pdf
Please note that I could not find the referenced RH Wheel Arch Liner Removal Section - But you can use the Illustration and parts list about the Wheel Arch Liner below.
Here are 2 JPEG files I created from the JEPC (Jaguar Electronic Parts Catalog):
1st one is a parts list & diagram that includes the Wheel Arch Liner:
Next one is the Windshield Washer Pump system parts list & diagram:
Hope this helps
Jim Lombardi
Old Apr 5, 2012 | 09:44 AM
CWigleyjr's Avatar
Thanks to both Stu 1986 & Jim Lombardi for the terrific info. This should do the trick. Much Thanks Guys,
Chet
Bcrary3
Sep 12, 2021 05:41 AM
picard
Oct 12, 2015 11:56 AM
corysansburn
Sep 10, 2015 06:15 AM
AtholC
Sep 9, 2015 09:07 PM
Super Cat
Sep 9, 2015 03:24 PM
