2000 XJR 308 Rear Side Marker Lights
Old May 26, 2018 | 08:13 PM
ColeD's Avatar
Default 2000 XJR 308 Rear Side Marker Lights
Hello guys does anyone know if the rear side light markers are interchangeable I busted the one on my 2000 xjr and I see a good price on one from a 98 xj8 - will it work? Any help would be appreciated thanks Cole
Old May 27, 2018 | 05:26 AM
ericjansen's Avatar
As far as I know, they all fit.
Just know there are reflectors, and there are lights, different species .....
Old May 27, 2018 | 07:57 AM
ColeD's Avatar
Thanks much for the info- this is a the light assembly that is on the rear drivers side - the actual reflector part of the assembly got cracked and I cant get the bulb to stay put- previous owner removed it incorrectly- so I need a replacement- thanks for the insight. Cole
Old May 27, 2018 | 08:45 AM
neurojag's Avatar
Cole, they will fit,like eric said.
I converted the amber European reflectors to the U.S-sidemarkers-lamp style with small LED's in it.
For example:
https://www.britishparts.co.uk/jagua...de-marker-p685
Old May 27, 2018 | 08:48 AM
Daim's Avatar
I've got a set of 4, 12 months old, all illuminated (originally). Fronts are amber, rears are red... Up for a good price if you want them...
Old May 27, 2018 | 12:41 PM
ColeD's Avatar
Thanks to all Daim I sent you a pm to find out your price - thanks Cole
Old May 27, 2018 | 07:21 PM
ericjansen's Avatar
Good idea, I have a full set in spare, for that day to come...
Found the plastic to be extremely brittle, maybe because of the heat from the exhausts.
Old May 28, 2018 | 11:04 AM
ColeD's Avatar
Thanks they are brittle - hoping Daims are what I need- Cole
BillyRay59
Apr 4, 2012 07:54 AM
comeoniwanttogo
Dec 1, 2010 09:32 PM
vincent661983
Oct 28, 2010 12:21 PM
