2001 X308 running crazy rich. I’m lost...
Old Jun 23, 2021 | 07:11 AM
  #41
bfx308's Avatar
Originally Posted by jacksjags
To clean the cat you remove the upstream O2 sensor and inject foam. It's a special foam to clean catalytic converters. Ideal is to inject little by little to ensure it really reaches the bottom of the honeycomb. That's it !!! Then you drive to heat it up.
Can you recommend a product to do this? I'd like to try before replacing the cats. Previously I've used the cat cleaning fuel additive and I didn't see any further cat error codes, but I'd love to do the cat-specific cleaning as well.
Old Jul 10, 2021 | 10:23 AM
  #42
jacksjags's Avatar
Hi bfx, sorry for the very late reply… I bought the cat cleaner cans off eBay. It’s a German product also used to clean diesel particles filters. Product name was PETEC. Works even better if your cat is warm. Not too much as you’d burn your hands but a 10 to 15 minutes idle will do.
Old Jul 10, 2021 | 01:24 PM
  #43
Jhartz's Avatar
I don't think this is a catalytic converter issue: I think you have dirty injectors: Try a can of a good fuel system cleaner (Gumout, Lucas, even SeaFoam, here in the States) and drive it.
Old Jul 10, 2021 | 02:33 PM
  #44
xjack's Avatar
Setting apart bad sensor code, running rich on one bank is most probably caused by injectors as Jhartz states, mine seems to require cleaning every few years, engine starts to misbehave accompanied by running rich on one bank and me trying to wrap my head around what has broke again, sending injectors for professional cleaning solves the issues, unfortunately in my case bottle cleaners didn't help but i try it anyway before sending.
Old Jul 11, 2021 | 05:27 PM
  #45
Jhartz's Avatar
Maybe right: as these crates begin to get some real age and wear, what worked when they were newer (SeaFoam) may not now. Still, give it a try before screwing with the cat converters.
jacksjags
Oct 17, 2020 06:14 AM
JagXK82001
May 2, 2017 04:32 PM
smtguy
Feb 16, 2016 03:22 PM
KyleSpeirs
Jan 28, 2014 01:51 PM
JimmyL
Jan 7, 2013 10:30 AM
