2001 XJ8 Alternator Removal
Old Jun 28, 2011 | 09:45 AM
Booty1313's Avatar
Default 2001 XJ8 Alternator Removal
Last night, I was following the JTIS alternator removal process, and everything was going peachy. Until I ran into removing the stupid multi-plug from the back of the alternator. HOW DO I PULL THIS THING?!?
I'm sure it's something super easy that I wasn't seeing, but no matter how much I pinched, pulled, jimmied, shimmied, jiggered, flabbered, and cursed, it wouldn't budge. It was getting late and I was getting tired, so I gave up. I'm hoping for some good advice here that I can take home and finish the removal with ease. I'm ready to feel dumb. Thanks in advance!
Old Jun 28, 2011 | 11:47 AM
mzs_biteme's Avatar
I had a hard time with it too, until I finally pressed the right thing. It has a small clasp, kinda like on most of the electrical connectors on the car. Don't remember exactly where on the connector is is, but it's there... Have you tried a little mirror to get a better look at it. Or a small digital camera... Also, when I changed the alternator on my 99 VDP, I went in through the wheel well, taking the wheel shroud off. Pretty quick and easy.
Old Jun 28, 2011 | 03:43 PM
Dan R's Avatar
The clip to release it is on the engine side (naturally) of the plug. Press it towards you to release.
I had to wrastle the alternator to get it off. The mounting bolt presses on a metal bushing to secure the unit to the mounting bracket.. You will need a long bolt, washers and nut to press out the bushing once the alternator is out otherwise it will be difficult to reinstall.
It's in the JTIS.
Old Jun 28, 2011 | 04:05 PM
Booty1313's Avatar
I've seen this in the JTIS, but it doesn't call out length and size of the bolt required. Can you give me a good sense of what I will need? I'd like to have it ready for the reinstall.
Old Jun 29, 2011 | 09:57 AM
Booty1313's Avatar
I got the clip off and the alternator off. I definitely had to wrastle it also. I can now see what's required for the bushing retraction to help the reinstall. Thanks for the help!
Old Jun 29, 2011 | 11:32 AM
Dan R's Avatar
This is the setup I used for the bushing/collar. The bolt has a 17mm head.
P.S. While you're there you may want to change the alternator brushes. Ay 140k mi mine needed changing due to corrosion on the terminals and brush wear.
Attached Thumbnails 2001 XJ8 Alternator Removal-trip-ireland-may-2011-bolt-137.jpg
Old Jun 30, 2011 | 10:20 PM
Booty1313's Avatar
The reinstall went smoothly. Thanks for the help, everyone. Retracting the bushing is definitely necessary for an easy install.
Old Jan 27, 2012 | 10:32 AM
a73uk's Avatar
Hi all,
I`m having a nightmare removing the alternator on my 99 XJR, been on it 5 hours so far (2 & 1/2 hours to remove the top mounting bolt as it was welded to the aluminium bracket, ripping out some of the thread in the process), I have now discovered that it doesnt seem to physically come out of the car...
Could someone point me in the right direction of this JTIS alternator removal process please?
Thanks.
Old Mar 22, 2015 | 06:06 PM
XJag801's Avatar
Default Trying to remove my alternator from my 2001 Jaguar XJ8
Originally Posted by a73uk
Hi all,
Thanks.
Hello,
Just came across your post today as I was searching the best way to remove my alternator from my 2001 Jaguar XJ8. I have everything unplugged and removed and the alternator is free floating but I cannot find a way to actually remove it from the vehicle. I see a sway bar I am tempted to remove hoping it will give me enough room to remove the alternator, but it still looks like if I remove it, it will still not be enough room. Do you have any tips or advice on how to remove it?
Thanks!
Old Mar 22, 2015 | 06:31 PM
dvjag's Avatar
Hi when I replace the alternator on my 1998 vdp I removed the fans , you can then lift the alternator up the front of the engine, ,,
regards
Dave
Old Mar 22, 2015 | 07:05 PM
motorcarman's Avatar
regards
Dave
BINGO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You can pull the fan shroud assy in a few minutes.
bob gauff
Old Apr 18, 2015 | 11:59 PM
ericpearce's Avatar
Just had the alternator go out on my 2003 VDP. It is less than 2 years old and was installed by a shop in Austin, TX as it died there while on vacation. When going to pull / replace today, i discovered the upper bolt head was broken off by the previous mechanic. I called and had a stern talking with the shop's Saturday advisor. Looks like I'm pretty much on my own. Any suggestions as to removing the broken bolt??? Does the mounting bracket actually come off as well?
Old Apr 21, 2015 | 09:07 AM
The aluminum mount bracket is bolted to the block BUT the fasteners are BEHIND the alt so it needs to be removed in order to get to the mount bracket fasteners!!!!!
You MIGHT be able to drive the bolt out the REAR of the mount ear (it is a steel threaded press fit piece) but I think the engine mount will interfere.
bob gauff
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
skadmiri1
Sep 9, 2015 11:27 AM
TexasCat
Sep 8, 2015 04:36 AM
jaguarbill
Sep 5, 2015 11:43 AM
