2001 xj8 RP on and amber engine light
Old Apr 9, 2009 | 03:45 PM
jeffd93's Avatar
Default 2001 xj8 RP on and amber engine light
Hi
I took the car to the dealer and had it scanned codes PO455 and PO333. They replaced canister valve C, car ran fine for 3 days. Then it all started again. RP comes on around 60 miles per hour, goes off when you slow down, but engine light stays on.
Any ideas?
Old Apr 9, 2009 | 04:01 PM
JagtechOhio's Avatar
You fix what you find, when you find it. The new warning could easily have been caused by another unrelated fault. Best have them scan the car again so no false conclusions are drawn.
Old May 19, 2009 | 09:21 AM
jeffd93's Avatar
had it checked agian/ Po333
How hard is it to change the knock sensor?
Old May 19, 2009 | 12:19 PM
wazari's Avatar
Changing both knock sensors is easy. It's just undoing the wire harness and removing the sensor. You will need a crow's foot attached to a long extension to loosen and tighten it with a ratchet. You should tighten it to 30 Nm.
Old Nov 16, 2009 | 09:23 AM
jeffd93's Avatar
ok sounds good what size crow foot am I buying and where do you stick the ext in for the drivers side knock sensor?
And is there a ton of anti freeze going to pour out?
Old Nov 21, 2009 | 09:38 AM
jeffd93's Avatar
Any help would be nice
ttt
Old Nov 22, 2009 | 11:50 AM
jeffd93's Avatar
Just went to change it and the one they gave me was a thread in and the one on the car is a stud and nut
Why did it show up on parts list as a threaded one.??
Does any one know the standard no# for the stud and nut one?
Threaded is a standard ks 308
Isoruku
Jun 19, 2020 12:54 PM
Robert1968
Jun 24, 2017 11:16 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
dpappyp
Aug 27, 2015 06:31 AM
