2001 XJR suspension noise
Old Sep 3, 2016 | 06:40 AM
jandouglass's Avatar
Default 2001 XJR suspension noise
I am getting a noise from my front susspension. It is a thumping sound that sounds like dribbling a basketball very fast two or three times. This does not seem to effect ride quality. I live on a cobblestone street and thats where you notice it the most. Any ideas?
Old Sep 3, 2016 | 08:29 AM
JTsmks's Avatar
Upper or lower shock bushes, anti roll bar bushes or end links.
Old Sep 3, 2016 | 11:12 AM
Are these repairs costly or difficult?
Old Sep 3, 2016 | 11:19 AM
harvest14's Avatar
Do you do your own labor?
Old Sep 3, 2016 | 11:26 AM
vdpnyc's Avatar
Or the shocks
Old Sep 3, 2016 | 11:29 AM
My shocks are only two years old (6,000 miles). I try to dp my own repairs unless it requires special tools.
Old Sep 3, 2016 | 11:40 AM
harvest14's Avatar
If the shocks are new, then the lower bushings are new so you should be able to rule those out.
The upper mounts would likely show signs of flaking etc. if they are going bad, but may not. If they look like they are disintegrating then order some new ones online; pretty darn easy to replace yourself.
Anti-roll bar bushings and end links are fairly inexpensive online also, and also pretty easy to replace yourself.
Old Sep 4, 2016 | 03:51 PM
Vector's Avatar
The bushings for the front upper shock mounts, the front sway bars and new sway bar links cost about $150 or less, total.
Do the rear sway bar bushings and links too while you are at it.
I did all the above and it made my 76K mile XJR drive like new.
The install is easy if you have jackstands and a few tools. The front sway bar is quite a bit larger and heavier than the rear though.
There are several "how to" threads on all of the above.
Vector
Old Sep 5, 2016 | 05:32 AM
Thanks again! I did find a how-to video for the sway bars and it seems do-able. I would imagine a little WD40 the day before might help.
Old Sep 5, 2016 | 11:55 AM
Vector's Avatar
It is really quite easy, just don't drop the heavy front sway bar on your head, lol!
And torque everything to specs.
Vector
dsetter
Jul 22, 2016 03:39 PM
DandyAndy
Apr 21, 2016 05:07 AM
xjtom
Mar 31, 2016 04:16 PM
jhamrick
Jan 26, 2008 11:19 PM
racerxf12004
Oct 4, 2007 07:02 PM
