2002 XJ8 water distribution pipe
Old Feb 21, 2010 | 07:33 PM
skydvr78's Avatar
Default 2002 XJ8 water distribution pipe
Does anyone know if there is an aftermarket aluminum water distribution pipe out there? I just installed the aluminum thermostat housing and discovered that the water distro pipe needs replaced as well.
Old Feb 12, 2011 | 12:18 PM
Bart's Avatar
Default Water distibution pipe
I have exact same situation. BTW how did you get to the two back bolts on the thermostat housing? A socket is too tall and there is not enough room to swing a wrench.
Bart
Old Feb 12, 2011 | 12:45 PM
sparkenzap's Avatar
Bart:
What you can do is use a propane or butane torch and heat the neck of a 10 mm wrench and bend each end about 80 degrees into what is commonly called a crowsfoot wrench. Its tedious, but you can get them out a lot easier than r/r of the manifold. Replace the bolts with socket head capscrews and you are good to go.
xjrjag
Oct 24, 2024 03:09 PM
1100me
Jul 24, 2023 06:10 PM
way2far
Aug 31, 2022 09:26 AM
Dicque
Sep 19, 2015 12:53 PM
1100me
Sep 7, 2015 06:26 AM
