2002 xj8 water pump
Old Feb 1, 2009 | 12:41 PM
hunterpayne's Avatar
Default 2002 xj8 water pump
Hello,
Need some help on installing a new water pump.The new WPcomes with a gasket and o-ring, but I am trying to determine where the o-ring actually goes. The old WP had the o-ring around the lip, but it has a groove for it. Does the new o-ring go at the end of the lip instead around the lip like the original?
Thanks for the help
Old Feb 1, 2009 | 01:29 PM
JagtechOhio's Avatar
Default RE: 2002 xj8 water pump
The newest style pump as updated a few years ago uses a flat steel gasket at the mounting face, period. I don't know what you bought, but it doesn't sound like that's what you got.
Old Feb 1, 2009 | 03:47 PM
The one that I took off has the flat steel plate, and an O-ring around the center opening that protrudes into the engine about 1/2 inch. This is an aftermarket water pump that does come with a gasket but no groove for the o-ring.
Old Feb 1, 2009 | 03:51 PM
This is the new one
Old Feb 1, 2009 | 04:17 PM
I am literally sitting here with a new AJ8 8912 pump in my hand, there is a flat steel gasket for the mounting face and no rubber O ring of any sort used for its sealing or installation. The aluminum gasket with bonded O ring is obsolete. What you have in your hands is what you got, and if it differs from mine it is not the latest style Jaguar factory water pump.
dsnyder586
Dec 29, 2024 07:39 PM
way2far
Aug 31, 2022 09:26 AM
ccfulton
Sep 20, 2015 05:15 PM
Dicque
Sep 19, 2015 12:53 PM
Saturbo
Sep 8, 2015 07:35 PM
