2003 XJ9 Rear Door Locking problem
Old Oct 29, 2010 | 03:41 PM
coxcr01's Avatar
Default 2003 XJ9 Rear Door Locking problem
My rear door driver side will not open, it is locked! One can pull up the door lock plunger, but it will pull back down. We have tried to remove the door panel, but it needs to pull it to the left from the inside to get it off! Removing the door hindge will not help!
Can anyone help with this please?
Old Oct 29, 2010 | 05:43 PM
benebob's Avatar
ud
Can you open it with someone holding it up inside and someone opening the door handle either inside or out? If not, you may want to figure out which fuse or relay handles the door lock mechanism and pull it. Other option would be to disconnect the battery but you'll loose some of your presets doing this.
Old Oct 30, 2010 | 07:31 AM
coxcr01's Avatar
No, the locking plunger pulls itself back down in the lock position when you let it go. The inside handle has no effect, although you can feel the connection between the handle and the locking plunger when you move the handle. I have disconnected the battery, no help.
Old Feb 21, 2011 | 08:20 PM
yardpro's Avatar
anybody ever figure this out.. mine just started doing the same thing
Old Feb 21, 2011 | 08:37 PM
pdog2000's Avatar
mine occasionally does this...i need to lock and unlock the car a few times and it goes away...annoying for the back seat passenger...would love to know what the permanenet fix is
Old Feb 21, 2011 | 11:50 PM
vdpnyc's Avatar
Do you really have an XJ9? Please take a photo of your 9-cylinder engine
Old Feb 22, 2011 | 06:51 AM
X308_XJR's Avatar
Mine was sticking intermittently also. I asked my indie to check it out while he had the car for some other service. He said parts of the mechanism were corroding, so he cleaned and lubricated it. No problems since then. It wasn't sticking nearly all the time, but I didn't want to end up in the situation described above, where you can't open the door at all.
Doubt this helps the OP, but to anyone else who has the beginnings of this problem, get it fixed before it becomes permanent.
Old Feb 23, 2011 | 07:43 AM
coxcr01's Avatar
Thanks all. First to VDPNYC--It is an XJ8. Second, same problem had dealer look at it and my friends Jag mechanic in UK diagnosed the problem and tried to replicate and repair but all to no avail. I have been advised that only option I have is to cut door panel! Thanks for all of your help.
Old Feb 23, 2011 | 10:05 AM
DavidN's Avatar
I doubt that you'll have to cut the doorpanel.
I just had a look at the rear door on my XJ8 and with the rear seat removed it should be possible to remove the panel even with a closed door!
I would give it a try!
Good luck!
David
Old Feb 24, 2011 | 06:52 AM
coxcr01's Avatar
DavidN,
Thanks for the reply. I did remove the back seat, and tried to remove the door panel. Unfortunately, in order to remove the door panel, I need to slide it towards the back of the car which I cannot do since the door is closed! I tried the right door panel and found this to be true. Bottom line, I cannot get the door panel off unless I can slide it back. I cannot slide it back because the door is closed.
CRC
Old Feb 24, 2011 | 09:43 AM
DavidN's Avatar
Sorry to hear that!
Old Feb 26, 2011 | 07:02 PM
yardpro's Avatar
bumping this thread..
hope someone has some input as mine is doing the exact same thing.
We cannot open the passenger back door... stays locked.
tried playing with the central locking but it did not work...
Old Mar 24, 2011 | 01:28 PM
yardpro's Avatar
just an update to this thread...
we could not unlock the passenger rear door.. not even with lifting the lock manually.
The origional poster was asking about removing the panel while the door is closed.
I just took my car to a body shop today and they were able to get the panel off with the door closed..
once they opened the door, the door lock now works fine...
SOOOOOOO.. the question now is do you think i need to still replace the actuator, and if so, I read somewhere about some ford part that is MUCHO cheaper than the jag one (Although the same part)....
any input on where to get a new one?
Old Mar 24, 2011 | 05:31 PM
vdpnyc's Avatar
My previous car had a similar problem, the incompetent dealership replaced parts "bumbilingly" and after a few tries it was finally was fixed.
During the tornado in NY last year the window got smashed in that door and after replacing it the problem came back, only the window repair guy was much more savvy - just banged quite hard on the outside of the door where the lock is a few times with the side of his fist and the problem was fixed and never returned
Old Mar 25, 2011 | 04:40 AM
Cadillac's Avatar
yardpro,
Why not check in with our vendors
NALLEY, JPAM
ebay
off the site
www.jagbits.com
www.motorcarsltd.com
Old Mar 25, 2011 | 06:02 PM
yardpro's Avatar
$120 was the best price on parts from the sponsors.. if i have to go that route, i will, but i read about some that were $20ish new... a ford part.
msdg137
Sep 16, 2015 06:24 AM
plmmd
Aug 31, 2015 10:07 AM
Tony Bow
Aug 28, 2015 05:17 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
Terrance Williams
Aug 26, 2015 11:50 AM
