2003 XJR Fuel pumps not working
Old Oct 5, 2024 | 04:42 PM
  #81
03_jaaag's Avatar
Originally Posted by Parker 7
Do you have the ability to test fuel pressure after ( actually it is before as it relieves higher fuel pump pressure) the FPR as on some models of the V8 there is a fitting on 1 of the 2 fuel rails on top of the engine ?
43 PSI
Nope my set doesn’t reach the schrader valve
Old Oct 5, 2024 | 04:45 PM
  #82
03_jaaag's Avatar
videos i was talking about
File Type: mov
File Type: mov
Old Oct 5, 2024 | 09:09 PM
  #83
Addicted2boost's Avatar
The first clip sounded exactly like a flooded engine that needed the restart.
Then the second clip sounded like since it’s running (rough) but with a nasty exhaust leak? Maybe you have a bent valve, burnt valve or timing off on one of the secondary chains.
Prior to your first post on 4/13/24, how was the car running? Is it possible that it had overheated?
Old Oct 11, 2024 | 11:19 AM
  #84
03_jaaag's Avatar
Thanks, will give it another shot with a restart. would valve or timing problems throw a code? my scanner isn’t the best. i got the car not running, was last on the road around 6-7 years ago.
Sean B
May 19, 2024 11:13 PM
Phreddie
May 19, 2017 10:18 PM
devxiav
Sep 25, 2013 09:29 PM
jkmspartan
XJ40 ( XJ81 )
Sep 3, 2013 09:03 PM
Noah
Oct 19, 2012 12:39 PM
