308 Sunroof panel retrieval
Old Oct 11, 2016 | 10:20 PM
dmpsqrd's Avatar
Default 308 Sunroof panel retrieval
Any collective wisdom on retrieving the rear 1/4 of the interior sunroof panel from it's hiding place in the roof would be DEEPLY appreciated....
Old Oct 11, 2016 | 11:15 PM
Johnny_B's Avatar
I second that.. My car has that too
Old Oct 12, 2016 | 12:21 AM
dsetter's Avatar
Tilt the roof, rear up.
Pull the inner cover assembly out from the rear from the outside, it just clips in.
Check that the two pivot arms are not broken.
Remove the three torx screw from each side of the sun roof and lift out.
Look down slides to see where the panel has gone. Coat hanger hook to slide it forward.
Very carefully bend the pivot pin backwards so that the arm will engage in the panel. Do not try bending the die cast arm. Only use pliers on the pivot itself.
Replace sunroof and align by reverting to closed.
Tilt again and slide cover back in and click it into the arms.
Old Oct 14, 2016 | 07:10 AM
jrb53's Avatar
thank you dsetter you saved me a lot of work I was about to remove the head liner to fix this problem. I fix the sun roof in about 10 minuets with your suggestion thanks again jrb53
Damon_Silvestry
Oct 18, 2016 03:18 PM
michaelodonnell123
Oct 13, 2016 12:06 PM
Dick
Oct 12, 2016 05:24 PM
Damon_Silvestry
Oct 10, 2016 08:56 AM
Lee Saxon
Oct 10, 2016 07:06 AM
