98 xj8 won't start
Old Aug 14, 2014 | 06:28 PM
Jmarley's Avatar
Default 98 xj8 won't start
I drive my car everyday and haven't had any problems with it all. I was leaving the bank yesterday and it wouldn't start. I guessed it just needed a little boost so pulled out my cables and jumped it. It started right up. As I'm leaving the bank it it shuts off again. I noticed that the car stuttered when I pressed the gas pedal. Now I'm thinking that I ran out of gas. Luckily I wasn't too far from my friends house and he brought me some gas. I think it was a 5 gallon can and we filled it up. Came back and put the gas in the car. It would not start back up. It's cranking but not turning over. I don't know what else it could be??? I know this site has a lot of experienced jag mechanics/techs..... Any ideas would greatly appreciated
Old Aug 14, 2014 | 06:49 PM
RJ237's Avatar
Almost guarantee the fuel pump is bad.If you can locate the fuel rail under the plastic engine covers, you will find what is called a schrader valve, looks just like a tire valve. With the key on,depress the pin, holding a rag under it to catch fuel, if you are lucky. If no fuel spurts out, either the filter is clogged or the pump is bad.
When you have time please visit the new member area and introduce yourself.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Aug 15, 2014 | 07:32 AM
Jmarley's Avatar
Thanks for the response RJ237. When I turn the key to the on position I hear a click from fuse box under my backseat. Not sure what that is??? I did what said and nothing came out of the valve. Going to check my fuel filter later today. Was wondering if a dirty air filter would prevent the car from stopping
Old Aug 15, 2014 | 08:01 AM
Jmarley's Avatar
My check engine light is on and battery light is also on when I turn it over.
Old Aug 15, 2014 | 08:18 AM
RJ237's Avatar
They will be on until the engine starts.
Old Aug 20, 2014 | 03:34 PM
Jmarley's Avatar
Is there anyway to remove fuel tank without removing fuel lines leading into the gas tank?? Could I remove the line by disconnecting from the fuel filter?
Old Aug 20, 2014 | 06:22 PM
RJ237's Avatar
In a word, NO. Do a search of fuel pump replacement and you will find lots of help.
I intend to replace mine later this year by cutting the shelf above the tank, but many others would not do that.
Disconnecting the tank to replace the pump is a pain, but it is the approved method.
Old Aug 20, 2014 | 06:46 PM
Sean B's Avatar
That's one side you can let go leaving the filter attached, if you've skinny arms or know some wirey youth that can shove the release clips home then disconnecting them isn't tough. There's also a picture of a tool Avos made from heating pipe with a slot cut in the top, shamfered edge and could be pushed home with the car on the ramp making this an easy painless way. I'll try and find the picture as fuel pumps quitting is now all the rage.
Old Aug 20, 2014 | 07:13 PM
avt007's Avatar
If you choose to replace the pump, check out the fuel pump DYI in my signature. It's for an XJR, but the only difference should be the extra pump the R has.
Old Aug 23, 2014 | 02:58 PM
Jmarley's Avatar
I know I've seen a lot of people on here replace their fuel pump with the airtex brand. I normally order my parts from rockauto. Just wondering if anyone else on the forum has ordered a fuel pump from rockauto
Old Aug 23, 2014 | 08:48 PM
motorcarman's Avatar
I have used the DENSO replacement pumps but the rubber mounts in the metal bracket need to be 'modified/cut' to fit the replacement pump. (sharp knife)
The URO brand is a DIRECT size fit with the same electrical connector but I don't know if it is the same quality as the DENSO. I have installed the URO when customers bring their own parts. So far no one has returned with a failed pump.
Most times you need to purchase a filter 'sock' or the pump warranty will be void.
bob gauff
Old Aug 24, 2014 | 02:23 PM
avt007's Avatar
I bought Densos from Rock Auto, check out the fuel pump DYI link in my signature.
Old Sep 8, 2014 | 12:01 PM
Jmarley's Avatar
I finally got past those gruesome fuel lines and removed the old fuel pump. I decided to go with airtex brand after reading about other members satisfaction with it. It only took about two hours for the whole process and now my cat purring again
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
Charlene n John
Sep 28, 2015 06:01 AM
Broken_Spanners
Sep 6, 2015 11:34 AM
Charlene n John
Sep 6, 2015 11:03 AM
