98 xjr overheating
Old Sep 21, 2011 | 07:18 AM
pat57woods's Avatar
Default 98 xjr overheating
Overheated at idle. Replaced water pump and thermostat and figured as long as I'm in there I'd put a smaller sc pulley on it. Now it blows all the coolant out on the highway. It can idle all day long and drive as long as I don't boost it. Passed a chemical analysis of the coolant that checks for exhaust gases so it should not be a head gasket. Any ideas?
Old Sep 21, 2011 | 07:54 AM
test point's Avatar
Blows it out where?
Get all the little hoses back on to the throttle body?
Sounds like you need a cold engine pressure test.
. . . and welcome to the forum!
Old Sep 21, 2011 | 05:23 PM
sparkenzap's Avatar
I agree with test point. Or, figure out where the coolant is coming from. I bet you cracked one of the connectors up there on the front of the engine. And relax, I seriously doubt this has to do with the boost. Especially if it does not show "hot". You're sure the thermostat is in the right way, right?
Old Sep 21, 2011 | 09:23 PM
pat57woods's Avatar
Sorry should have mentioned that. Its coming out the overflow tank.
Old Sep 22, 2011 | 06:09 AM
sparkenzap's Avatar
The tank in the left fenderwell, right? If so, do you understand my comment about swapped bypass tubes on the expansion tank?
Old Sep 22, 2011 | 06:23 AM
pat57woods's Avatar
Yes the tank in the front passenger corner. I don't see a comment from you about swapped bypass tubes on the expansion tank. Is there suppose to be a tube coming off the bottom of that tank? Mine doesn't, only has the nipple that the coolant is coming out of.
Old Sep 22, 2011 | 08:28 AM
sparkenzap's Avatar
Have a look at this:
https://www.jaguarforums.com/forum/x...d-fixed-60665/
The crossed lines can :happen: on the expansion tanks, the one where the coolant cap is.
I assume you mean driver's (left side) or is there a Corpus Chriti in the UK? :<)
Good Luck.
Old Sep 22, 2011 | 10:03 AM
test point's Avatar
A fail reservoir cap or one not sealed completely will cause the overflow tank to overflow.
There is a hose coming from the center bottom of the reservoir.
Old Sep 22, 2011 | 08:19 PM
pat57woods's Avatar
Thermostat was in backwards. No more all nighters. Thanks for the help.
vwbusbits
Oct 13, 2015 03:43 AM
Tipptone
UK & Eire
Oct 1, 2015 10:50 AM
vwbusbits
Oct 1, 2015 01:17 AM
BlacXJRcat
Sep 25, 2015 06:43 PM
mhenz
Sep 14, 2015 07:47 PM
