99 VDP - All O2 Sensor Heater Circuit Codes
Old Aug 30, 2016 | 12:04 PM
KidRock'n's Avatar
Default 99 VDP - All O2 Sensor Heater Circuit Codes
Hi gents,
Just had the CEL come on this week, showing a failure of the heater circuits for every o2 sensor on the car. Is there a central fuse or relay that could be toast? Feeling like this is probably a single-source issue. As always, your thoughts are appreciated.
Best,
David
Old Aug 30, 2016 | 01:37 PM
avern1's Avatar
The heated O2 sensors are controlled in 2 ways. First is power from a 30amp fuse at #11 iin the engine management control fuse box. It is the smaller one under the bonnet. The second is some are equipped with a relay #6 in the passenger side control box with a 10amp fuse at #14 in the engine management control box.
The heated sensors are only the uppers. The relays are all the same so you can switch one around if yours was equipped with relays. I recommend relay #2 that one is the A/C clutch relay and won't effect engine operation.
Old Aug 30, 2016 | 05:10 PM
KidRock'n's Avatar
Thanks for the information. I'll check out the fuse box tonight and report back
Old Nov 19, 2022 | 09:12 AM
qsaghar's Avatar
Default Any reports on the fuse situation?
Was a blown fuse or bad relay the problem ?
Old Nov 19, 2022 | 02:36 PM
motorcarman's Avatar
The post is 6 years old and some people just NEVER reply back to let us know the answer.
AZ RICH
Jun 12, 2018 01:35 PM
Mike Lore
Jun 9, 2018 07:34 PM
34by151
May 19, 2018 05:42 AM
phil_xjs_conv
Jul 8, 2017 11:56 PM
dynoguy
Jul 26, 2015 07:00 PM
