'99 VDP Thermostat Housing
Old Jan 31, 2018 | 12:35 PM
cliveb's Avatar
Default '99 VDP Thermostat Housing
Hi everyone, although my '99 VDP ,with 74K miles, is running just fine currently, after reading the many posts on this forum, I'm taking the preventative action and preparing to replace the timing chain tensioners on my X308 motor, and while it's apart I intend to replace the water pump, which I understand has a plastic impeller. I also thought about replacing the plastic thermostat housing with the aluminium type, however the readily available ones on Amazon and other sites are either the URO at around $55, and the APA at over $90, neither of which have great reviews. Does anyone have a good quality metal alternative they could recommend. The current housing does not leak.
I thank you in advance for any suggestions here.
Clive
Old Jan 31, 2018 | 12:59 PM
avern1's Avatar
Take a look at SNG Barratt, Jagbits and Welsh Enterprises web sites. I have had good dealings with all 3 over the years and recommend their units. Prices go up and down based on availability/stock so I always compare the three.
Old Jan 31, 2018 | 01:32 PM
Samilcar's Avatar
I installed the SNG Barratt (https://www.ebay.com/itm/Jaguar-XJ8-...item3addaf0f30) and have had no problems.
Old Jan 31, 2018 | 02:12 PM
King Charles's Avatar
I got mine from Welsh on E-Bay was sub $50.
https://www.ebay.com/itm/Jaguar-XJ8-...-/262669723228
Old Jan 31, 2018 | 03:37 PM
RJ237's Avatar
+1 Welsh. Wherever you get it, make sure you replace the thermostat, and I highly recommend replacing the crossover pipe and the short hose at the same time.
Old Jan 31, 2018 | 05:53 PM
ericjansen's Avatar
From my observations, there are 2 qualities out there, hard to determine which is which though.
Seems the one from the big UK suppliers is good, the other one seems to show up with leaking problems sometimes.
I bought mine from the UK, including a new thermostat (!), no problems.
BTW. if you paint it black before install, it stands out much less in the engine bay.
Old Feb 1, 2018 | 01:04 AM
cliveb's Avatar
I checked Welsh, Jagbits and Barrat and barrat was the least expensive at $44, however their water pump was $215,whereas Welsh was $36 and Jagbits was $100. That's quite a spread. I like the idea of painting it black Eric Jansen.
Old Feb 1, 2018 | 01:09 AM
Keep in mind the $44 EB Welsh kit I linked includes the thermostat as well.
Old Feb 1, 2018 | 03:26 AM
ericjansen's Avatar
Originally Posted by cliveb
...however their water pump was $215,whereas Welsh was $36 and Jagbits was $100
You live in the US, I bought my Airtex waterpump (OEM) from Rockauto.com, 39 bucks it I remember well.
Old Feb 1, 2018 | 03:30 AM
Water Pump : Airtex AW4124
Old Feb 1, 2018 | 06:13 AM
toaster's Avatar
Clive
ÜRO is a part of APA-Industries, i had never a problem with ÜRO...................
https://www.ebay.de/p/Jaguar-Vanden-....c100005.m1851
Old Feb 1, 2018 | 10:19 AM
cliveb's Avatar
I took a look at the Airtex AW4124 water pump on Ebay, the price is nice, but it looks like it has a plastic impellor. Can anyone confirm that?
https://www.ebay.com/itm/New-Airtex-...NaYXfl&vxp=mtr
Old Feb 1, 2018 | 12:00 PM
Jhartz's Avatar
I bought the tower from Welsh, along with the new crossover pipe (which includes a new temp sensor). Also buy the stubby hose. My airtex wp leaked. Second time, went with AC Delco -- flawless and far less expensive.
Old Feb 1, 2018 | 03:53 PM
The newest Airtex has a steel impeller.
Old Feb 1, 2018 | 05:32 PM
ericjansen's Avatar
By now, 20 year later, my concern should not be the 'plastic' or steel discussion (plastics technology came a long long way), but the design of the vanes.
I have read on various forums that the design of some steel vanes induce cavitation (bubbles due to vacuum, on the backside of the vanes).
If so, it will deteriorate your steel vanes much quicker than 2018-plastics will due to age.
I do have to add that I only have this info from forums (which is the usual "hear-say"), but I know what cavitation is from my naval engineering background.
It is something you don't want inside your system.
PS. I think the Airtex is still "plastic", just a different color and different material than the problematic 90-tish version.
Old Feb 1, 2018 | 05:40 PM
For what it's worth the newest Airtex including the one I bought recently has the metal/aluminum prop.
Old Feb 1, 2018 | 06:39 PM
RJ237's Avatar
Some additional info on metal impellers: I bought one for my 97, but the casting was extremely rough, which I'm sure would promote cavitation. I used my Fordham flex shaft tool and small files to polish the vanes.
Old Feb 2, 2018 | 04:05 PM
If you're going to run the gambit & do all the hoses, this caught my eye.
https://www.ebay.com/itm/Jag-4-0L-NA...s/192279510256
preacher
Aug 13, 2024 01:07 PM
jagxk82005seneca
Jan 12, 2015 08:37 PM
akubeta
Sep 26, 2013 06:38 PM
djpxk8
Sep 30, 2011 09:59 PM
CarBizIndio
Aug 9, 2011 08:38 PM
