99xj8 fuel filter / o-ring stupid question
Old Jul 27, 2010 | 08:46 PM
Rae's Avatar
Rae
Default 99xj8 fuel filter / o-ring stupid question
OK, silly question time. Replaced fuel filter last night, unknown to me before I removed old filter was that o-rings are used on end of fuel lines at connection to filter. I should've realized something was up, when I saw the straight threaded fitting with no flare fitting recess in filter. Anyhow, I buttoned up without the use of new o-rings. Should I go to the trouble of chasing down new o-rings (dealer I presume) and install to prevent future complications, or if it doesn't leak now, do you reckon things will be fine? I'd hate to develope a leak over the exhaust pipe. I know what you're thinking, the textbook answer is to replace the o-rings. I quess I need a shove in one direction or another. I've got some stubby wrenches enroute, pain in the neck with standard length wrenches. Stop laughing......
Thank you,
Ralph
Old Jul 28, 2010 | 05:37 AM
Sean B's Avatar
Originally Posted by RAE
....... I'd hate to develope a leak over the exhaust pipe.
get them in there.....
Old Jul 28, 2010 | 09:04 PM
Rae's Avatar
Rae
Default Done Deal
Sean,
I knew better. In the interest of time, I located some at the local Jag dealer today. Will pick them up and install. Just needed slapped around...a bit.
Thanks for the reply.
Ralph
aholbro1
Dec 29, 2024 06:46 PM
Sprayall
May 30, 2021 08:13 AM
deanh
Sep 6, 2015 08:20 PM
lordpeterk
Sep 6, 2015 01:50 PM
Sprayall
Sep 3, 2015 07:49 PM
