abs pump unit replacement
Old May 16, 2012 | 03:57 PM
domer94's Avatar
Default abs pump unit replacement
i have to replace my whole pump unit shortly. when i disconnect the hard brake lines going into the top, is it just a matter of bleeding the brakes as normal once the new unit is in? farthest wheels first etc etc
Old May 16, 2012 | 10:09 PM
motorcarman's Avatar
Why are you replacing the hydraulic unit??? If you are replacing the ABS module it is unnecessary to remove the brake lines and hydraulic assy.
bob gauff
Old May 17, 2012 | 08:47 AM
domer94's Avatar
yes, replacing the whole hydraulic unit.
Old May 17, 2012 | 09:12 AM
Sean B's Avatar
It's the closest brake caliper to the pump first on these, goes against the grain but that's JTIS advisory.
Old May 17, 2012 | 10:30 AM
domer94's Avatar
noted sean , thanks. also will there be a prolific spillage of brake fluid when undoing those lines? shall i cap them with vac blanks or something?
Old May 17, 2012 | 01:11 PM
Sean B's Avatar
not unless it's powered up, just make sure you're ready with the exchange unit, and plenty of rags around so as not to spill the fluid.
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Russ Graber
Feb 23, 2019 11:59 AM
Sprayall
Sep 3, 2015 07:49 PM
innzane
Sep 2, 2015 10:08 AM
