Adaptive cruise control
Old Apr 8, 2016 | 02:38 PM
Bcrary3's Avatar
Default Adaptive cruise control
I am curious was adaptive cruise control ever offered on the x308? If so what year did it begin?
I am curious because I see a light for it on my instrument cluster (original).
Does anyone have a photo of the sensor for the adaptive cruise?
Thanks!
Old Apr 10, 2016 | 08:36 AM
andrew lowe's Avatar
Adaptive cruise was never an option on the X308.
Are you sure that the clocks are original to that car? I say that because it was an option on 2003 XKs and the clocks are the same.
Old Apr 10, 2016 | 08:59 AM
yeldogt's Avatar
Never available in USA -- what does the light look like ??
Old Apr 10, 2016 | 05:01 PM
The symbol is the back of a car on a road with a <---> arrow behind, it is located above the message centre to the left of the amber and red warning lights.
Old Apr 10, 2016 | 11:26 PM
JBzXJ40's Avatar
That wouldn't have started till the XJ350, the 308 never had adaptive cruise in the NAS market. But the symbol that you're describing, does it have a triangle around it? Those arrows are related to the Forward Alert.
Old Apr 11, 2016 | 11:31 AM
Bcrary3's Avatar
There is no indication it has ever been replaced, previous owner doesn't recall replacing the cluster.
Were these cars equipped with forward alert? Or was that after 2000?
Symbol looks like number 14.
Old Apr 11, 2016 | 02:47 PM
yeldogt's Avatar
Wishful thinking on VDO's part?
Old Apr 11, 2016 | 02:51 PM
That is a 2003 on XK clock set, not a X308.
Old Apr 11, 2016 | 03:14 PM
Bcrary3's Avatar
That's what my x308 has in it, and as far as I can determine, it's completely stock, the symbol doesn't light up, and I didn't notice it until I had taken the cluster out to add a RealGauge.
Was the x308 ever equipped with forward alert (2000)? I just have no idea what that's all about.
Old Apr 13, 2016 | 04:15 AM
As said before, the X308 NEVER had "forward alert" or adaptive cruise control fitted as standard, or even as an option from the factory.
The clocks seem to be from a 2003 or later XK, that did have adaptive cruise control as an option.
Having said that, Jaguar at the time was owned by Ford.... and they are notorious for parts bin engineering, but that dose not explain a later version of the clocks being installed in your car.
Old Apr 16, 2016 | 05:48 AM
redpoptop's Avatar
Hi,
Our X308 which is a 2002 MY also has the same dash board clock set with the adaptive cruise lamp on the overlay. Which is a 3.2 unit.
perhaps ford were trying save money by fitting the same units as per the XK series .
Redpoptop
Old Apr 16, 2016 | 11:42 AM
Presence's Avatar
I am with the original poster -- my 2001 XJR has the Adaptive Cruise Control light in its cluster, too. I have often wondered what it is.
Old Apr 21, 2016 | 10:39 PM
JBzXJ40's Avatar
Adaptive cruise and forward alert weren't available till 2003, at least in the NAS market. As for other markets, I'm not sure. Since I've been in NZ for the past 5 years, I haven't seen any pre 2003 cars with forward alert or adaptive cruise. When it comes to the wiring harnesses, Jaguar makes them for all the features available, to cut down on cost, and then depending on how the car is ordered, only those modules will be fitted, but the connector will still be there. It also could be that if the Instrument Pack was replaced, it was at a time when they were starting to make updated ones for the facelift models coming out that would have forward alert and adaptive cruise.
Old Apr 22, 2016 | 09:41 AM
luc's Avatar
luc
Not really.
NA cars not fitted with NAV do not have the ICE harness to support NAV.
And that is only 1 of many examples......
Old Apr 22, 2016 | 11:51 AM
Presence's Avatar
Pic I took in this morning.
Old Aug 3, 2016 | 07:47 PM
Brian XK8's Avatar
Can adaptive cruise control be added to a 2002 XK8 convertible? Like others, I have the light on the clock. If I can get one close to "plug and play", I'd be interested.
Old Aug 3, 2016 | 08:23 PM
Vector's Avatar
IIRC, the hardware is not easily obtained unless you get it from a wreck and those who have it OEM find that when it fails, cost to repair is something outrageous like $1500.
Vector
unicorn
38
Jul 31, 2023 03:19 PM
dartech
Apr 9, 2016 09:28 AM
collector
Apr 7, 2016 03:43 PM
rolexslk2007
Apr 7, 2016 08:43 AM
JagV8
Apr 4, 2016 10:01 AM
