Adjust differential pinion play ?
Old Oct 6, 2011 | 02:37 AM
popeye68's Avatar
Default Adjust differential pinion play ?
Hi Guys !
My XJR '99 has a fair amount of pinion play , felt when breaking<>pulling up.
I double checked if it was the diff by turning the driveshaft by hand , clunking noise came from the diff.
Question ; is it possible to adjust the play with the two rings on both side's of the diff (see picture) without opening ?
If so ,what is the right procedure ?
b.t.w. my diff is still on the car , the picture is from some market-site
Thanks !!!
Marcel
Image upload did not work (?)
here's the pic ImageShack® - Online Photo and Video Hosting
(Note the ribbed ring with adjustment slot)
Old Oct 6, 2011 | 09:13 AM
Brutal's Avatar
No you cannot, and pinion bearing preload is set on the pinion nut after removing the driveshaft and jurid coupling. You need some amount or slack or youll burnup gearsets and have alot of whinning before you do.
Old Oct 6, 2011 | 11:05 AM
popeye68's Avatar
mmmm , that's to bad ..
i was hoping for an easy fix
But are these ribbed rings for adjusting backlash on this diff anyway ?
Old Oct 7, 2011 | 04:36 AM
popeye68's Avatar
Correct me if i'm wrong ,but after some more study it seems the ribbed rings on the side of the diff are there to adjust the camber ...
Old Oct 7, 2011 | 09:33 AM
Brutal's Avatar
yes adjust those and your diff will get really noisy. Those are to adjust axle bearing preload
DFW
Jul 27, 2020 02:44 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Woznaldo
Sep 26, 2015 11:02 AM
