after market warranty question
Old May 28, 2010 | 11:40 AM
goodz4u2's Avatar
Default after market warranty question
any one know of any companies that will cover jags with after market warranties ?
Old May 29, 2010 | 03:20 AM
Fairlane500's Avatar
I believe it will depend on the year of the Jag, but I have a 3 year warranty on my 03 Jag from Global. I purchased the warranty last July.
Old Jun 1, 2010 | 11:03 PM
qwiketz's Avatar
man, when I priced them out it was super high cost....
Old Jun 2, 2010 | 01:44 PM
ef4ervescent's Avatar
Default Extended car warranty
I'm looking into extended car warranty for my 2000 XJ8. My partner came across a company called "Canadian Warranty Corporation", www.canadianwarrantycorp.com.
The price seems too good to be true. Does anyone have any experience with them or any other company?
Old Jun 4, 2010 | 07:58 PM
goodz4u2's Avatar
I'm finding that most companies will not give one on a jag or landrover due to dependability issues and high repair cost unless you are still in your original factory warranty.
Old Jun 4, 2010 | 08:14 PM
Brutal's Avatar
problem is to get a warranty on your car is about as much as the car is worth. And any that do and are reasonable wont cover much except powertrain and with alot of exclusions. I would set up a "car fund" instead
Old Jun 4, 2010 | 09:51 PM
orca99usa's Avatar
The ones that do, and don't charge a king's ransom, are very careful to exclude most anything likely to go wrong. I found that out when I had a cooling system problem with my '99 XJ8. Since Jaguars have a lot of parts in the cooling system that don't appear on other cars, naturally nothing I needed was on the list of covered parts. With the help of the good people here I found an excellent parts source, got back on the road and learned a lot about my car in the process. The warranty was useless, however.
Old Jun 5, 2010 | 08:45 PM
jeffn's Avatar
How about AAA warranties? They seem to be a bit more above board than the typical warranty insurers(like Warrnty Gold which went under a year after i bought into their warranty).
Old Jun 7, 2010 | 08:24 AM
Sean B's Avatar
what Brutal says, as much use as a chocolate fire guard, consider finding a good independent and start saving, unless you're handy with torx and metric spanners.
Forcedair1
Sep 8, 2025 01:57 PM
Wolfy
May 28, 2024 08:06 AM
VRB
Sep 15, 2015 08:18 AM
SeanU
Sep 13, 2015 02:45 PM
SeanU
Sep 11, 2015 12:56 PM
