ahhh crap.
Old Oct 14, 2007 | 04:49 PM
Max's Avatar
Max
Default RE: ahhh crap.
Here is what the JTIS lists as posssible problems for the P1396. Has nothing to do with tensioners.
ECM to VVT solenoid valve circuit fault
(refer to P1392, P1393) - see below -
VVT solenoid valve actuator sticking
Oil supply fault
VVT unit fault
Camshaft drive fault
CKPS / CMPS circuits fault(s)
(refer to P0335, P0340) - see below -
P1392
Fault - ECM to VVT solenoid valve circuit open circuit, A bank
Possible causes - ECM to VVT solenoid valve circuit open circuit,
high resistance, short circuit to high voltage
VVT solenoid valve failure
P1393
Fault - VVT solenoid circuit short circuit A bank
Possible causes - ECM to VVT solenoid valve short circuit to ground
P0335
Fault - CKPS circuit malfunction
Possible causes - CKPS disconnected
CKPS gap incorrect / foreign matter on sensor face
CKPS sensing circuit open circuit, short circuit to ground, short circuit to high voltage CKPS failure
P0340
Fault - CMPS circuit malfunction
Possible causes - CMPS disconnected
CMPS gap incorrect / foreign matter on sensor face
CMPS sensing circuit open circuit, short circuit to ground, short circuit to high voltage
CMPS failure
Old Jan 6, 2008 | 06:03 PM
FactoryJaguarTech's Avatar
This is not timing chain tensioners. This indicates the VVT unit is bad. Either blocked or bad solenoid. A bank is passenger side (U.S.A). The VVT unit is in front of engine at top. I think you said 98 car. I think they changed half way thru model year to on top of cam covers at front of engine. If you have to replace them, do the tensioners at this time. Will save you thousands in the future.
Old Oct 10, 2020 | 09:01 PM
edreddy's Avatar
I can definitely do the primary and secondary tensioners. How do I figure the time chain to ensure it’s properly set after I replace the tensioners?
Old Oct 11, 2020 | 08:08 AM
Highhorse's Avatar
Review this old (but still applicable) detailed thread by blackonyx on doing the chains and locking the cams, its pretty cut and dry.
Tmingi chain and tensioner replacement
Found in the "How To" section at the top of this forum... https://www.jaguarforums.com/forum/x...k-links-20090/
Dale Dunn
Nov 15, 2016 09:45 PM
kchirume
Nov 17, 2010 06:37 AM
ronmexico
Oct 30, 2010 12:09 PM
chupacabra
Mar 5, 2009 03:53 PM
westbay
Jan 17, 2009 09:05 AM
