Alternative to X308?
Old May 11, 2016 | 12:25 AM
Forcedair1's Avatar
I'm curious to know what the shop will find this time. I wonder if the no-track ABS issue ever goes away for good once your car has suffered it and repairs have been made. Somehow I am pessimist about it randomly coming back unannounced any time in the future again, but I will try to do all of the recommended preventative actions to keep it at bay.
Cheers,
Old May 30, 2016 | 08:29 PM
Forcedair1's Avatar
Originally Posted by Mark SF
What you are doing is extrapolating your experience with one car, to all X308s. Why dont you just get one that works properly?
Owner of an 02 XJR that works perfectly.
You turned out to be quite correct, Mark.
More on this coming up...
Cheers,
Old May 30, 2016 | 09:06 PM
Forcedair1's Avatar
Well, it seems like we may have conquered the problem, at least for the time being. The mechanic (who also worked on it years back) determined that, since I was able to fence off the limp home mode by keeping rpm's above a certain level and for long periods of time (freeway drive) and lasting until traffic slowed down again, the pot in the TB became the obvious culprit. He went straight at that and replaced it and now the problem has totally disappeared . It was obviously that and I assume that the fix will last for a good while.
So, wow, I have a healthy X308 again and I'm already doing what I promised: take care of what I have postponed up to now because of the issues. I'm putting new leather out front, plus a new headliner (it needs it), plus getting repaired a small dent that I put on the rear, below the trunk lid. Since this car's paint has never been touched at all, meaning no buffing, no paint, etc. ever, it will easily withstand a good buffing job followed by a good professional color-wet sanding in the fashion that my XJS paint was done. If the XJR paint turns out at the level of the XJS, the car will look absolutely phenomenal.
Following this I will have all the suspension components examined and updated and do the brakes and the shocks, then spark plugs replacement. This should buy me some 10K or 20K more miles of pleasure driving my supercharged beauty.
Cheers,
Last edited by Forcedair1; May 31, 2016 at 04:16 PM. Reason: clarifying a statement
Old Nov 17, 2016 | 11:34 AM
rf69's Avatar
My XJR has now done 135K. It's just had its second fuel pump swap, so that's an average of 67K miles lifetime, for the pumps. It failed on my last XJ8 at about 75K. Apart from that, both cars have been very reliable.
I have the service history back to new for my XJR. There's nothing too extraordinary in it. Apart from routine maintenance, and many, many sets of brake pads(!) :
Two new control arms at 30K.
Throttle body at 48K.
New ABS controller at 65K.
Fuel pumps at 79K.
ECU at 95K.
Water pump and belts / idlers / belt tensioners at 133K.
Fuel pumps again at 135K.
Well, the ECU is a bit unusual. Otherwise, though, it seems to compare well with other cars in its class.
Right now I'm going through it and refreshing the suspension with new bushes and shocks. It's due. No error messages, warning lights, and everything works - and I mean everything - even the memory steering wheel and seat adjustments.
Good info do you know what were the faulty symptoms of your fuel pump ?
My 04 XJ8 has 132k miles on it and once in a while the gas gauge in the instrument panel marks empty when is actually full
Old Nov 18, 2016 | 01:41 PM
Stu 1986's Avatar
There isn't any alternative, believe me I've tried. When my last XJ8 died from a combination of gearbox failure I tried something else. Yes it was a lot newer than a 308 and it was a bit faster than a 308 too. It's more modern automatic gearbox did some interesting things, and the Xenon lights turned night into day. However it missed that special something that the 308 had, that little spark that made me smile and enjoy every single journey be it to the local shops or to Belgium. I sold the replacement and the same day bought my new X308 and I'm absolutely loving it.
Old Nov 19, 2016 | 11:39 AM
XJDanny's Avatar
My 2002 XJR has been reliable too. I've had it a few years and I am in love with my car.
The biggest thing I did was replace the secondary tensioners but besides that, I've only had to do routine things such as replacing worn bushings, replacing fluids, etc. I do have a slow freon leak I can't seem to solve but a couple charges a year keeps my air ice cold. And I've had the trifecta ABS/Trac lights come on a couple times but that went away both times after a day or two. Oh, and I have to buy a $30 connector part for my transmission. But everything works and the car is a dream to drive.
The X300's are nice. I used to have a '96 and I loved it. I don't think they compare to the X308's though but that's just me. I've thought about an X358 to upgrade to more modern technology but they just don't move me like the X308's do. They look like an X308 that needs to go on a diet. I think the X308 is the most beautiful sedan Jaguar ever made. Well, maybe not including the Series III. :-)
Old Nov 19, 2016 | 10:25 PM
Count Iblis's Avatar
I think the X308 is gorgeous too, it looks almost exactly like the still born All new XJ90- that Jaguar were developing before Ford took over.
Although I prefer the XJ6/12 series 1 to the series 3 in some ways, the rear roof line of the old series one is more sloped and that aggressive snarling front grill...
Old Nov 19, 2016 | 10:38 PM
  #28
ericjansen's Avatar
Gorgeous indeed.
This picture from Dimitri still intrigues me, and shows that our x308 is perhaps more related to the series 1~3 then we sometimes think.
Old Nov 20, 2016 | 12:39 AM
Here are some pics of the XJ90 concept from Whitley before Ford cancelled it. You can see it looks very much like an X300. Has some subtle differences to the way the headlights are splayed (the way they are on an X350) and it was intended to have a totally new IRS design. Probably would have carried over Powertrain from the ill fated XJ41 with its twin turbo six. Remember, during this time due to folks like Murray Betts, a V8 config was very much frowned upon.
Attached Thumbnails Alternative to X308?-img_0590.jpg   Alternative to X308?-img_0591.jpg   Alternative to X308?-img_0593.jpg   Alternative to X308?-img_0592.jpg
Old Nov 20, 2016 | 03:08 AM
  #30
Stu 1986's Avatar
That's really interesting Count, thanks for sharing. I always enjoy looking at concept cars.
Whilst I think the X308 is the most beautiful 4 door car that has ever or will ever be made, there is one thing I wish had been done differently. That is the exterior door handles had been recessed into the bodywork rather than sitting proud of the door skins.
Old Nov 20, 2016 | 09:16 PM
  #31
If you prefer the XJ40 style handles I'm sure they can be retro fitted. Aside from having broadly the same structure- the only panels that the X300 and XJ40 share are the doors!
Old Nov 20, 2016 | 09:42 PM
  #32
ericjansen's Avatar
Then I presume you know these ones, if not, happy reading:
Concepts and prototypes : Jaguar XJ40, part 1 - AROnline : AROnline
Concepts and prototypes : Jaguar XJ40, part 2 - AROnline : AROnline
Old Nov 21, 2016 | 02:34 AM
  #33
Stu 1986's Avatar
No, I wasn't referring to the XJ40 handles which would look wrong on the curvaceous body of the X308. What I think would have been better is if Jaguar had taken a short amount of time to change the steel press that made the doors so the handles sat flush to the body. If you look at both the X Type and the S Type they have nice curved handles set into the body, but the X308 handles seem like an afterthought.
Eric: I hadn't seen that article, thanks. Although I am no fan of the XJ40 it is interesting to see how it developed. Many of the early concepts were disgusting looking, when you see the exterior shots with series 2 & 3 XJs in the background it really shows how bad they were.
Old Nov 21, 2016 | 03:00 AM
  #34
ericjansen's Avatar
DAMNNN ... I never noticed that, but now, after checking the X type, I will not be able to open my car and not be bothered about the afterthought handles .
Old Mar 18, 2017 | 01:09 AM
  #35
tahoemedic's Avatar
Now that the wheel bearing is fixed I drove 8 hours to Phoenix in the 90+ deg weather. A/C worked great and she drove so smooth. Gonna detail her out in the morning then take her to a local car show in the evening
Old Mar 18, 2017 | 01:36 AM
  #36
ericjansen's Avatar
Actually I am really wondering how Forcedair1 is doing with his XJR after he seemed to have solved his problem ... Never saw pictures of that tremendous polishing he was going to do.
Old Jun 14, 2017 | 05:51 PM
  #37
Johntechwriter's Avatar
To my highly biased mind the X308 is the most beautiful post-war sedan EVER, and with current styling so overwrought, and influenced so negatively by safety features, I can't see much competition in the near future.
I'm on my third X308. My Jags are serviced at a non-dealer, Jag-only shop and after swapping out the timing tensioners and a few other plastic components, have been exceptionally reliable.
I'm still kicking myself for parting with my 2001 VDP Supercharged. I won't make the same mistake twice now that my '01 XJR has been scrupulously debugged and remains an absolute joy to drive. Why do German luxury car owners eye our Jaguars so enviously? Because our cars have sex appeal and theirs don't!
Old Feb 19, 2020 | 01:51 PM
  #38
Carl Dameron's Avatar
Default I own them all
Originally Posted by pkoko
I have owned 1994 xj40 XJ12 and 2008 XJ8. I have also driven 2002 x308 VDP. Here is my 2 cents...
The V12 is way better and smoother than the 4.0L v8. The XJ12 was also quicker and IMHO a more logical interior. The leather/plastics/wood was better on the XJ12. Braking was better on X308 and handling/road noise ~even.
The x358 is a huge upgrade performance wise. It is faster; more comfortable, more agile, better brakes than any xj40/x308. The 4.2 V8 is very smooth and fuel efficient. The 4.2 is a big upgrade from 4.0 especially at slow speeds. Is it as smooth and linear as V12? No; but it uses almost half the fuel. X358 is as quick on the highway where the V12 is meant to excel.
The X358's interior isn't as high quality though. The wood trim doesn't feel as nice. The switch gear cover for windows is plastic (not wood). The headliner is lower quality. The seats are better and IMHO will age better. The car has functional cup holders.
I wouldn't hesitate on x350/8 to replace your XJR. It still looks like a jaguar and attracts complements.
i have an 85, 91 and 95 xj6’s. I also have a 2003 stype with the 4.2 l V8. I love them all. They all have some small quirk but the engines are bulletproof. I daily drive the 91, 95 and 03. They are fun. I’m also keeping them all!
All my Jaguars 3 XJ6s and a V8 s-type
adam699
Oct 13, 2015 05:53 PM
10 XF Premium
Oct 2, 2015 09:22 PM
waynepaulj
Oct 2, 2015 04:05 PM
CaptainHam
Oct 1, 2015 02:01 AM
