Any possible chance to get the trunk open?
Old Nov 7, 2018 | 09:47 AM
  #41
CharlzO's Avatar
Curious on those pictures, since I don't remember what it was like when I pulled my subwoofer out. Is that a factory opening, or was that cut in by a previous owner to access fuel lines and pumps?
Which brings me to #2.. in my XJR, there's quite the gas tank behind the rear seat, so opening or no, there's not a whole lot that would be done to access the trunk.
Old Nov 7, 2018 | 10:25 AM
  #42
Carnival Kid's Avatar
Originally Posted by CharlzO
Curious on those pictures..............., there's quite the gas tank behind the rear seat, so opening or no, there's not a whole lot that would be done to access the trunk.
That's what I was thinking too.
Old Nov 7, 2018 | 02:55 PM
  #43
grandell's Avatar
Pretty sure that's an X350, not an X308
Old Nov 8, 2018 | 09:19 AM
  #44
rf69's Avatar
I don’t really know to be honest I did that because I needed the trunk opened and I was desperate.
i bought the car used 5 years ago and it is a Jaguar 2004 XJ8 a 350 for sure.
I was told that there’s not access through the rear seat
but I found that aluminum cover plate and the opening is from factory not doubt about that . I was really surprised and happy when I saw that opening
Old Nov 8, 2018 | 09:39 AM
  #45
CharlzO's Avatar
That's the difference - two different cars. The X308 has the gas tank smack dab behind the rear seat, so even if you did cut a whole in the rear seat back (there's no factory opening), you'd have no way to access anything, since you'd just have the tank up against it.
For the X308s, the only ways I know to access the trunk, are the button on the fob, the key itself, trunk button on the lid, and the dash button. With a dead battery, then you're stuck with the key, or if the cylinder is froze or broken, you can try to connect cables to the positive post under the hood to provide power to then use the power releases. And last resort, drilling the whole behind the license plate which can then allow use of a thin screwdriver or other tool to manually release the latch.
It is one of the few things I wish the car had, was a pass-through rear seat, but moving the tank would mean the lines of the X308 wouldn't be as slim as they are.
BadKat174
May 26, 2023 12:29 AM
DuhCar
Sep 11, 2015 10:58 AM
findre
Sep 10, 2015 05:46 PM
speacock
Sep 10, 2015 12:14 AM
kstevusa
Sep 7, 2015 01:12 PM
