Anyone have any idea what these are and what they're for?
Received 12,741 Likes
Hi Bcrary3,
If those connectors are original and not part of a previous owner's audio modification, then they are probably for optional equipment not installed on your car, or were used while the car was in transport to the dealership to prevent battery drain and such. The answer is probably in the 2000 X308 Electrical Guide, which you can download at this link:
http://www.jagrepair.com/images/Auto.../jagxj2000.pdf
Cheers,
Don
Cheers,
Don
XJRay (08-12-2015)
Hi Bcrary3,
Cheers,
Don
Cheers,
Don
I'd be interested to know what you find as well - I was wondering the same thing last week as I was dismantling my car to install an mp3 cable.
I also found a huge multi-cable electrical connector in the back of the center console near the rear vents that didn't go into anything, and was capped of; I figured it was for some Vanden Plas option that the XJR didn't come with.
The black connector has a earth, a constant +, and a + through a relay (which probably is not fitted).
That connector comes in handy for an additional power outlet in the trunk, which I did for a 12V cooler box.
Not sure what you mean by that, but are you implying that it is possible to hook up bluetooth in this car?
If you want to install a Bluetooth device (like a Parrot or Motorola) for phone use only, you can use this plug completely, as the plug was intended for the original Jaguar-Motorola phone unit.
If you want to install the same Bluetooth device using the full potential of all your speakers, you can still use part of this plug for the power supply, but will need to connect the output to your CD player cables (exact configuration depending on your type of audio).
Do a search and there are several threads on this.
I did this several months ago, and it is an absolute delight to stream my music from my Samsung Note's SD card.
~4.000 songs just a click away, no desire for the CD player at all.
Yes, that is what he means .
In doing it will I be able to use the steering wheel/dash control to operate it?
I have the parrot unit fitted and hidden in the center console between the front seats.
Once paired one time, it will connect automatically if I enter the car, and streams music and phone calls from the phone if the CD is chosen.
The steering wheel buttons for volume etc. work just as normal, but phone operation needs to be done from your phone (but the Bluetooth device provides voice dialing etc).
Once installed, you will never want to go back to the CD player operation ...
I can only speak from experience with my Parrot 9000, but I presume it is more or less the same for any other device.
Yes, using that connector you can get to all the signals necessary to connect a Motorola T605 or other Bluetooth phone interfaces. Sounds and works great with my T605, plus it can be used as a AUX input by connecting the T605 thru the CD player connectioon for Bluetooth and AUX music playback as well.
Does the power continue to flow after that vehicle is turned off? If so, how do you stop your cooler from draining the battery?
