Autoenginuity OBD II reader
Old Sep 2, 2023 | 06:49 PM
LionelT's Avatar
Default Autoenginuity OBD II reader
I have a 2002 XJ8 that failed its smog test because I replaced the battery recently. I was not aware that disconnecting the battery would erase the ECM memory. This causes the sensors to report "Not Ready", and fail the smog test.
I also have an Autoenginuity diagnostic tool that I have used successfully to diagnose the ABS system and misfire issues. I want to read the Inspection / Maintenance codes to see which tests are "Not Ready". But when I select the "Onboard Test Results" tab, every parameter shows "Not Supported". Anyone have any idea what could cause this? The manual clearly shows that the reader has this capability. I have not been able to get help from Autoenginuity.
Old Sep 3, 2023 | 09:01 AM
JagV8's Avatar
You may be in the wrong menu.
You want the status of each OBD monitor, which is standard OBD.
Old Sep 3, 2023 | 05:34 PM
LionelT's Avatar
Thanks. Attached is a copy of the report it generates for IM / Mode 6 results.
File Type: pdf
Old Sep 5, 2023 | 08:56 AM
JagV8's Avatar
You're looking in the wrong place (again)
OBD monitors are "mode" (not the correct name but it's used a lot!) 1
https://en.wikipedia.org/wiki/OBD-II_PIDs
Old Sep 6, 2023 | 05:08 PM
LionelT's Avatar
Thanks for the link! I will have to study this, as I've never done this before.
The smog test flagged “comprehensive component”, “catalyst”, and “oxygen sensor” monitors as “not ready”. My problem is that I need to drive the car a few hundred miles to get the sensors ready so I can register it, but I can’t drive it because it’s not registered! Here in California, driving with expired registration will get your car impounded!I’m also my wife’s primary caregiver, and can’t spend a lot of time driving around the landscape. Plus, Jaguar shops seem unwilling to fix it. Anybody know of a Quick Fix?
Old Sep 6, 2023 | 06:35 PM
Ken Cantor's Avatar
California would appear to issue temporary permits for non-registered cars as well as temporary permits for cars that fail their smog tests that give you time to repair and retest them.
https://www.dmv.ca.gov/portal/handbo...t-top-reg-19f/
Good luck!
Old Sep 7, 2023 | 07:33 PM
LionelT's Avatar
Thanks for the tip Ken. That's exactly what I need!
silvertonesx24
Aug 2, 2023 05:38 PM
alanroberts50
Mar 14, 2018 10:58 AM
UL Ysses
Jul 17, 2016 05:55 AM
cully
47
Feb 27, 2016 02:06 PM
Robert Scott Neilly
Jul 14, 2011 08:38 PM
