Bad fuel pump connection, '03 XJ8
Old Feb 3, 2018 | 06:09 PM
RSpi's Avatar
Cool Bad fuel pump connection, '03 XJ8
I pulled a fuel pump yesterday and was about to install the new pump and noticed that the connection at the pump is bad. Is there an easy source for these? Looks like it was a short.
Old Feb 3, 2018 | 07:57 PM
nilanium's Avatar
Did the new pump come with a connector?
I got the Denso kit with filter, which included any wiring needed. The connector was also different than for the pumps that were in the tank, probably OEM. If it's an OEM pump you got, you may be able to source a harness, part no LNC3360CA
Old Feb 3, 2018 | 09:55 PM
RSpi's Avatar
Yes it is a Jaguar pump.
Old Feb 4, 2018 | 06:45 PM
yeldogt's Avatar
When the pumps start to go they often pull more amps and can overheat the connector -- this is common. I guess enough to melt the connector and not pop the fuse. Jaguar sells the harness if it needs to be replaced along with a new pump.
I believe you will find the pump is bad .. pulling too many amps
Old Feb 4, 2018 | 06:49 PM
JBzXJ40's Avatar
Yep, also check the EVAP flange at the the top of the tank as well, sometimes the pins get burnt on that end too.
Old Feb 5, 2018 | 09:07 AM
RSpi's Avatar
Does anyone know the PN?
Old Feb 5, 2018 | 10:25 AM
RSpi's Avatar
No direct part for the primary pump that I could fine. Was able to find a PN for the secondary pump in the dual pump supercharged models that can be spliced in. Got it on eBay new for $135. Local price was $185+tax. PN: LNC 3360CA. Used would have been $25.
Another horrible pitfall for the fuel pump job. lol
Old Feb 5, 2018 | 02:43 PM
avern1's Avatar
Here is a link to SNG Barratt web page for a blow up of the fuel tank components. They have the link you are looking for.
https://www.sngbarratt.com/us/#!/Eng...S%20AND%20ORVR
If you haven't done so yet take advantage of the free download of their electronic catalog. It's great for parts ID and assembly blow ups.
car5car
May 18, 2016 05:16 AM
dburdette79
Jul 30, 2014 02:18 PM
SparkyGage
XJ40 ( XJ81 )
Apr 18, 2014 01:01 PM
philhef
Jun 15, 2013 05:21 PM
markwow79
Apr 3, 2010 11:41 AM
