Battery replacement inquiry.
Old Jan 26, 2016 | 04:33 AM
King Charles's Avatar
Default Battery Replacement Inquiry
Old man winter has finally sat down here in lovely coastal NC. Now my battery is too drained to crank after 2-3 days of sitting dormant in freezing temps(FH).
My question is, as I install the new battery if I run one of those battery boosters that connect via the cigar lighter. Will that suffice to keep me from having to re-program everything, as well as the car's ECUs from re-learning !?
I will link the booster I plan to use.
Amazon.com: Stanley P2G7S Simple Start Lithium Battery Booster: Automotive Amazon.com: Stanley P2G7S Simple Start Lithium Battery Booster: Automotive
Old Jan 26, 2016 | 05:22 AM
avern1's Avatar
As soon as you remove the negative cable the booster would no longer be a complete circuit and I doubt the booster would continue to work.
Old Jan 26, 2016 | 05:28 AM
Yeah my basic knowledge of circuits told me as such, but after all it is a Jag, the host of many electrical eccentricities, so it was worth the proverbial shot lol.
Old Jan 26, 2016 | 05:47 AM
sparkenzap's Avatar
On a Jaguar, as well as most cars theses days, the cigarette lighter circuit is powered through a relay. If that relay is pulled in when the power supply is connected tot he lighter, then it will continue to hold the circuit on until the voltage drops too low to hold the relay in.
There are other places to inject power to the bus to hold the controller memories, like the OBD plug. I think this has a risk of, at best, blowing a fuse, or worse damaging the wiring if a sudden high load is inadvertently connected, such as what might happen if the security alarm was set off and the lights began flashing.
Old Jan 26, 2016 | 05:52 AM
Yea I was going to go out and tinker w/ different spots to power but it was 4 am EST so I will @ least give my neighbors until dawn in case alarm sounders & horns run a muck lol.
Old Jan 26, 2016 | 11:52 AM
Update : I did the booster in the accessory/cigar lighter outlet & had every thing set up for the battery switch so it was literally under 5 minutes to install. She fired right up, threw me a ghost "gear box fault" message that went away the next start (also 1st time I've ever seen that warning w/ this car) yet to resurface. All my settings were normal, no reprogramming necessary.
+1 for rapid battery replacement w/ booster !
Old Jan 26, 2016 | 12:38 PM
Jhartz's Avatar
Maybe just a temporary fix (those are always good); still, you know you need to drop by your local Advance Autoparts, have it load tested, and . . . .!
Old Jan 26, 2016 | 12:49 PM
No sir. I meant by replacement that I had a brand new battery ready to go, I just didn't want to deal with everything resetting.
I had all the tools, the new batt. setting inches away(on a towel draped over trunk lip) as if it were open heart surgery to ensure the little booster kept the circuit, while I transplanted w/ lightening speed lol.
Old Jan 26, 2016 | 01:41 PM
sparkenzap's Avatar
There really should be NOTHING that you would notice with "everything resetting" except maybe the radio presets
Old Jan 26, 2016 | 01:44 PM
Better safe then sorry is my mantra lol, I've heard the ECU resets and the car runs rugged until it re-adjusts etc. Either way all's well, as the lion purrs tonight.
Old Jan 26, 2016 | 02:43 PM
Jhartz's Avatar
It took a couple of minutes for mine to reset when I bought a new battery last month, same same when they put in a new alternator. About the same time it takes for everything to stabilize after a hard reset. But . . . I like better safe than sorry.
Old Jan 26, 2016 | 03:11 PM
Yes sir I have big boy CCA now, the old unit was clocking in around 330ish.
Old Jan 26, 2016 | 03:36 PM
Jhartz's Avatar
Where did you buy the Ghibli? The Maserati sales manager at Charles Barker sold me three Land Rovers. Couple of blocks away.
Old Jan 26, 2016 | 05:19 PM
Johnson Maserati of Cary | New Maserati dealership in Cary, NC 27511-7933
Old Mar 25, 2016 | 09:12 PM
Lear45's Avatar
I replaced my battery without having supplemental power during the swap. You will
reset time on the clock and that's about it. The engine relearns everything on its own.
Sometimes it becomes a little smarter too!
XxSlowpokexX
Apr 3, 2016 06:51 AM
Sarc
XJ40 ( XJ81 )
Feb 13, 2016 07:26 PM
Dickie_L_J_O
Feb 5, 2016 07:50 AM
Mark in Maine
Feb 3, 2016 06:19 PM
tryitonce
Jan 26, 2016 03:42 AM
